Offroad & 4x4
D44 rebuild advice
Old 05-03-2010, 07:14 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
D44 rebuild advice
In about a month, I plan to rebuild a solid d44.
Has any of you done one of the little (as in not a Rockwell or a d60, etc) axle rebuilds.
I plan to strip it down to the housing and do an overhaul.
I need help selecting all the replacement parts and getting
it ready for my SAS in to the Bronco.
Iʻll step by step everything in my Build thread in the Bronco forum too.
Old 05-03-2010, 07:19 PM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
what do you want to know?
look here for replacement parts, gears, lockers and misc stuff.
Welcome to Complete Off Road - Rich is the man!
Old 05-03-2010, 08:23 PM
fatdan460's Avatar
fatdan460
fatdan460 is offline
i saw the title and that you replied and expected to see "the best rebuild advice is to find a 60". i'm kinda curious about this too. like cost of a good set of aftermarket axles and who makes the strongest ones, and are they worth it? i can't find 78/79 d6o fronts at anywhere near a reasonable price. so i might just beef the d44
Old 05-03-2010, 08:33 PM
WideOpenFord's Avatar
WideOpenFord
WideOpenFord is offline
X2 I would also like to know, cause there are some bullet proff mud trucks where i'm from on alcohol runnin D44 and 9 inch!!! How do they do it!
whats the diffrence between this:
D44 YUKON HARD CORE Chrome Moly Front Axle Set
and this:
Dana 44 YUKON Chrome Moly 4340 Front Axle Set
both chrome moly? Mabie i'l be the first to find out.....
Old 05-03-2010, 08:39 PM
WideOpenFord
by the way hey guys im eric
not really new here just new to posting in the 4x4 fourm
i got a build commin up here soon, il be posting my progress and hopefully getting some good insight from you guys!
Old 05-03-2010, 08:44 PM
fatdan460's Avatar
fatdan460
this forum is a little more aggressive, so be prepared, it's all in good fun
Old 05-03-2010, 09:02 PM
alpha/omega
lots of varibles for all the the questions asked.....
Yukon makes the crappiest chromo shafts - especially for the 44.
I havent kept up with the new stuff available for axles but Superior made the best shafts a couple years ago and probably still today. CTM makes the best u-joints.
^^^ this setup will cost over $1000 and still not near as strong as a stock 60.
it all depends on the use of the truck.
here are some D44 vs D60 comparisons
The reason a D44 will last in an alcohol straight line drag is because the u-joints are their strongest when the tires are 99% of the time pointed straight and there is nothing to really grab the tires and shockload the shafts. Put that same engine in a trail truck and the axle wont last 2 seconds. The rear 9" is most likely not stock. 35 and 40 spline shafts are the norm.
again, it all depends on use of the truck.
This truck has a 700ci BBF with 2 500shot NOS foggers and uses a D35 front from a Cherokee and a 40sp 9" - not to mention a Chebby 208 tcase bolted in upside down behind a powerglide.
Old 05-03-2010, 09:34 PM
WideOpenFord
good point, i've been thinkin about using the 79 d60 i have for my truck but like you said for straight line mud drag the extra weight is not worth it.
Old 05-03-2010, 09:43 PM
alpha/omega
if you are building a mud drag only truck then use a 44 all the way.
rjbuningsr
06-12-2014 05:19 PM
brian1080
01-09-2014 11:49 PM
wodges
07-01-2013 01:31 PM
nobodyspecial
Offroad & 4x4
28
04-17-2011 07:24 AM
JereThei
Offroad & 4x4
41
02-18-2011 05:44 AM
Quick Reply: D44 rebuild advice
