intermittent start
Old May 3, 2010 | 01:10 PM
powersmoked's Avatar
powersmoked
Originally Posted by leoparleur
Driver's side (primary as I understood). I remove the #1 spark plug, the one at the foremost on front of vehicle. Only one coil cracked, it is the secondary coil (the one closest to the firewall).
keep the plug in and disconnect the main wiring harness to the coil closest to the firewall and see if it starts
Old May 3, 2010 | 01:14 PM
powersmoked
I positive I don't have ICM, the signal is directly fed from ECM.
i have a 99 I don't have a ignition control module.......if you have a 95 you do have an ignition control module. go to rockauto and you will see wha tit looks like
Old May 3, 2010 | 02:08 PM
leoparleur's Avatar
leoparleur
Before trying what you suggest, I had to put the spark plug back in place but wanted to adjust the gaping before. I measured 0.050. It is suggested 0042 to 0.046 (Haynes). These plugs are 1 year old. Now that I put back this plug in place the truck now starts and runs fine. Argg! Now I don't know if I'm experiencing the intermittent phase or not.
I cannot check your test as the truck starts at this present moment and runs fine.
Earlier, about an hour ago my brother suggested to check if I had a good ground point at cylinder head. I've hooked booster cable from neg bat post to top of engine and also tried neg bat post to coil pack chassis bolt. Neither test permitted the truck to start. So I guess I have correct ground supplied to cylinder head. and ground is not the source of problem.
Old May 3, 2010 | 02:22 PM
powersmoked
I have seen some people suggest. to take a spray bottle that will mist and fill it with water.. at night away from lights with the engine running mist the coils wires etc and look for sparks......if it sparks you might have found your issue.
Old May 3, 2010 | 02:24 PM
leoparleur's Avatar
leoparleur
Rockauto suggest one. I see what it looks like.
Autozone suggest this location: Under hood, driver side, lower engine area, mounted on intake manifold assembly...I cannot find it
From dealer documents (Mitchell repair information) and Haynes there are none.
I just contacted dealer, they say no ICM but TFI module is engine mounted. They could not give me more info on location.
Old May 3, 2010 | 02:28 PM
leoparleur's Avatar
leoparleur
I've experienced this often in the past, it works very well for spark plug wires. I know this test is valid when checking for sensitive spark plug cables to humidity. The truck will not run fine, mine does when in operation. I could still do the test.
Old May 3, 2010 | 02:31 PM
powersmoked
look on rockauto.com so you know what it looks like. I dont know much about the pre 96 obd-ii pcm's. I thought you had an obd-i and that the tfi was before that but i am not sure.
Old May 3, 2010 | 02:56 PM
leoparleur's Avatar
leoparleur
Know half an hour later, truck wont start anymore. I tried right away what you have suggested earlier by unplugging rear coil pack: wont start, front coil pack: wont start
I went on Rockauto, I saw what it looks like...I can find it under the hood, it's maybe in a crampy place.
Dealer just confirmed that there is no ICM but rather the PCM that controls as per Haynes and Mitchell schematics I have in hand.
Question: Dealer say there is a TFI but I thought thse were only used in motors with distributors mine is distributor less.
DesertZuki
Nov 24, 2015 03:29 PM
Doctomario777
Mar 12, 2013 07:59 AM
redthhies
Apr 9, 2010 09:25 AM
pike_hunter
Feb 22, 2006 11:08 AM
bhenders
Jan 21, 2006 06:36 PM
