Weak Spark / Hard Start
Old Jan 21, 2006 | 03:04 PM
bhenders's Avatar
bhenders
Angry Weak Spark / Hard Start
I have an intermittant hard start condition with my 1989 F-150. (302, 5 Speed, 137,000 miles.)
In testing for a spark at the plugs, I get a very weak yellow spark jumping an .045 Spark Plug gap. (Had hoped for a nice fat blue/white spark.)
New plugs, plug wires, dist cap, and rotor. Rebuilt dist and TFI unit( from Napa) and a new coil. No avail. Have also cleaned all grounds.
Will often start up just fine. When it acts up it will just barely fire and then die out. Can smell fuel. Really hard to get it started after that.
Thinking it is this weak spark deal, everything in the fuel system is new.
Special thanks to the many good responses in this forum. This is my first post. Up to now I have always been able to find my answer by searching other's problems.
Old Jan 21, 2006 | 06:36 PM
Popa Tim's Avatar
Popa Tim
Not sure.... but a weak 12v to the coil would cause a weak spark. I would start by checking the voltage into the coil and looking for corrosion. Then checking the contiditon of the batt, batt cable, solenoind, and Alternator. Lastly clean up you connections (+/-) at the battery. (+) at the solenoid, (-) at the block, frame, and body.
ps - these trucks are commonly found to have corrosion inside the battery cables. Maybe you should start there.
alexanselmo8
57
Feb 27, 2016 08:20 PM
lamarbEzy
1978 - 1996 Big Bronco
May 9, 2014 04:44 AM
beckman
Bronco II
Dec 17, 2013 03:05 PM
Hellbore
35
Jun 11, 2006 01:40 AM
jdunphy
Jan 8, 2005 10:07 AM
