2000 ford ranger shift problem
Old Apr 30, 2010 | 09:04 PM
jsinscho25's Avatar
jsinscho25
I have a 2000 ford ranger extended cab 3L v6 automatic, speedometer is not working, overdrive off light is flashing and the truck is not shifting out of first gear properly. I changed the speed censor on the back axel. I am confused can anyone offer what to do
Old Apr 30, 2010 | 09:07 PM
fire240's Avatar
fire240
Might want to ask your question here.
Ranger & B-Series - Ford Truck Enthusiasts Forums
Old May 1, 2010 | 12:42 PM
LxMan1's Avatar
LxMan1
You need to scan for codes. The flashing OD light indicates a trouble code is stored.
Old May 2, 2010 | 12:26 PM
powersmoked's Avatar
powersmoked
Those symptoms as a whole do point to the speed sensor. did you clean the area off good before you poped the sensor back in. I wonder if after you pull the codes if you reset the pcm if that might help. just curious did you check your rearend fluid level while you were there..........I also vaguely remeber reading something about 2 wiring harmesses that are right next to the fuel filter that can get contaminated......
Old May 2, 2010 | 12:29 PM
powersmoked
after you changed the vss/abs sensor did it work at all even for 5 minutes. Did you install a motorcraft one or an AZ special
Also when you say the speedo does not work do you mean it does not work at all or that it is erratic
Old May 3, 2010 | 07:38 PM
Rockledge's Avatar
Rockledge
Good memory: Ford Truck Enthusiasts Forums - View Single Post - 2000 Ford Ranger Overdrive light flashing
wheelchairdude49
36
Oct 15, 2015 09:02 AM
Travis88
Jul 4, 2013 09:20 PM
Ranger_Diesel
Feb 17, 2011 05:17 PM
jsinscho25
May 2, 2010 12:42 AM
baxter17
Apr 29, 2010 09:44 AM
