69 ignition trouble
Old Apr 7, 2010 | 11:51 AM
redthhies's Avatar
redthhies
69 ignition trouble
My 69 F100 with 240 and T18 won't start. I have tried new coil, wires, plugs etc. All the connections appear to be good. I have no spark. I tried putting a plug on the coil wire and grounding directly to the frame and still nothing. Any ideas? I need this truck to get to work and I am at a loss. Is there anywhere between the coil and ignition key/switch that could cause a no spark situation? I have ruled out distributor and grounding problems as I have done the coil to frame test. Thoughts???
Old Apr 7, 2010 | 12:42 PM
dwildey's Avatar
dwildey
Could be as simple as a bad fuse or possibly a bad ignition switch?
Maybe this will help you trace?
Old Apr 7, 2010 | 07:34 PM
redthhies's Avatar
redthhies
Probably not that simple as when I tried to crank it with the dizzy cap off, I noticed the rotor was not turning while the crank/fan was... Snapped/stripped distributor shaft???
Old Apr 7, 2010 | 11:37 PM
DarrellJ's Avatar
DarrellJ
Broken timing chain?
Old Apr 9, 2010 | 04:39 AM
DesertFE's Avatar
DesertFE
OUCH! Dizzy not spinning?
- Depending on where the points ended up, you may never build enough voltage in the coil to create a spark.
- If it's a sheared pin in the distributor gear you may not see spark...
- If it's a broken timing chain as DarrellJ submits you wont have proper compression in the cylinders or proper distributor operation... Unfortunately, Ford used plastic teeth on the camshaft gear and I have seen these go. Pull a valve cover to see if everything is moving. One blessing is - non-interference valves.
Old Apr 9, 2010 | 09:25 AM
redthhies's Avatar
redthhies
I may have to sink to new lows and drive my friends 68 GMC until I get time to open things up... I am now shopping for a 12v Cummins 4x4 truck to drive for a while, then maybe put the F100 body on it some day! That would be the dream work truck for me as I love the Cummins but hat the Dodge body.
ymirr
Apr 6, 2017 07:42 PM
mudder_lover
29
May 4, 2011 08:59 PM
bfktwb4
Dec 1, 2009 07:26 PM
53rat
17
Oct 7, 2009 07:26 PM
Jcon7487
Jul 1, 2008 11:55 PM
