Rear shock mounts
Old May 1, 2010 | 12:05 AM
abrauer's Avatar
abrauer
Rear shock mounts
I am putting a 9in rear in my 52 f-1 and was wondering if anyone knows where I can find a pair of F-2 shock mounts for the axle. I have no welding experience and was told if i could find some that would solve having to weld them on the axle.
Old May 1, 2010 | 02:53 AM
55 f350's Avatar
55 f350
dont know about the bonus builts , but in the case of the 53-56 i was told and procured a set of shock mounts from stu from a f250 for mine . from the same years of trucks mind you as they used bigger diffs and they had 3'' axle tubes like the 9'' does . of course now i'm not using them ... they won't work on a bonus built as tim checked 'em out on his . if worse comes too worse check out speedway , mid fifty 's new bonus built catalog , don't know what it's called the catalog , or maybe some odd out of the way things like ballistic fabrication . they are an custom 4x4 fab shop that makes all sorts of trinkets that can be readily adapted to anything . you got to think out of the box to solve things sometimes !!!!!!!!!!!!!!!
Old May 1, 2010 | 05:27 PM
dongc1's Avatar
dongc1
The F-2 brackets are the way to go. You see them on fleabay sometimes. Put a parts wanted add on the HAMB also. They are around, but you have to chase them down.
Old May 1, 2010 | 06:50 PM
Julies Cool F1's Avatar
Julies Cool F1
In about 2 weeks I'm taking my F1 (withthe 9 3/8 rear) back to the spring shop to have them make and install the shock mounts.
They said the stock set up does nothing!
I'll take some photos and post what they do when I get it back. If you haven't found your F2 mounts by then send me a PM and remind me!
Old May 1, 2010 | 07:10 PM
1oldtimer's Avatar
1oldtimer
anybody have pics of the F2 set-up? I bought the weld on lowers for the 9". I'm going to cut off the stock 9" brackets and weld on the new ones.
Old May 1, 2010 | 08:36 PM
firstrider's Avatar
firstrider
No Limit has them . Get a pair and weld them on .
OregonJen
1947 and Older Ford Trucks
Feb 11, 2012 12:19 PM
tsullivan
Dec 29, 2008 04:53 PM
erinaldi
16
Dec 17, 2008 05:52 PM
raygussy
May 18, 2007 02:25 PM
mgriffin
Mar 15, 2002 08:35 PM
