Help with shocks
Old Feb 8, 2012 | 11:58 AM
OregonJen's Avatar
OregonJen
Help with shocks
Does anyone have good suggestions on how to adapt a more modern front and rear shock for my 47 1 ton? The rear never had shocks, I found a nice 9 inch with 3.7 gears for the rear but how to do the shocks? I also have a set of hi-boy mounts from a 48 F1 but how do I attach it to the axle? Drill for a stud, weld one on or??
Thanks.
Old Feb 8, 2012 | 03:54 PM
COMPLIT1107's Avatar
COMPLIT1107
For the front, read this thread...
https://www.ford-trucks.com/forums/9...ck-mounts.html
For the back, check where the shocks from the 9" are attached and go vertical, then either weld in an x-member to mount shocks, or box a small section of frame and drill and install post bolts. Like:
Good Luck, Have Fun !
Old Feb 9, 2012 | 12:11 AM
OregonJen's Avatar
OregonJen
Shocks
Thanks for the help. I may try to drill a stud for the front and use the 48 hi boy mounts. For the rear, there isn't a mount on the axle so I will have to find or make a lower mount. The photos are a great help. Thanks!
Old Feb 11, 2012 | 09:08 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Here's another way to mount the rear shocks. I got the spring plates from Summit Racing and they have a bottom mount for shocks built in. The rear end is a 10-bolt Chevy from a 75 Malibu and the shocks are 53-55 Ford F-100...
Old Feb 11, 2012 | 12:19 PM
OregonJen's Avatar
OregonJen
Great ideas, thanks Vern...
GoldCo
Feb 26, 2017 07:37 AM
cooktimj
Apr 26, 2013 02:34 PM
Andy91st
Mar 28, 2012 08:04 AM
cseastaugh
Apr 4, 2005 12:44 PM
KJKozak2
Offroad & 4x4
Jun 8, 2004 05:11 PM
