I swaped from a 7.3 to a 6.9 and now I have 2 problems.
The lesser one is that I do not know were the wire for the tach should go.
The bigger problem is that after I had everything other than that fixed I fired it up. It started and ran great, but then when I went to shut it off it would not die. I had to pull the wire off the IP. I tried, but it will not come out of " on ". I can turn the key all the way forward and back, but it stays on.
not sure about the truck not shutting down but do you by any chance know what vehicle the new(est) motor came from?im thinking it might not have had a tach. but im thinking you can pull parts off the 7.3 to make it work
Here is a thread dealing with ignition wiring. Might be a good place to start.
Did you transfer all of the engine elec components, including the GP controller from the 7.3? When you shut the key off, does anything else stay on? Or just the engine?
As far as the tach sensor, you need to swap IP drive gear covers.
Remove the IP from the drive gear cover.
Now unbolt the drive gear cover and carefully remove it, leaving the IP drive gear meshed with the cam gear.
Now carefully install the IP drive gear cover that was on your old motor with the tach sensor in it.
Thinking about what could have short circuited to put power on the red/green wire to keep the engine running, but right now I am at a loss on that one.
The glow plug controller would be about the best cantidate I can think of right now since it has both battery power and ignition power on two terminals that are beside each other.
Not 100% sure, but I think the tachometer was only an option for 85 and 86.
I wonder if you got some wires crossed on the injector pump. Could it be you swapped the high idle/timing advance with the FSS connection? The engine would likely turn itself off after about 10 minutes of running if that were the case.
if you do not have any crossed wires, i bet the ignition actuator in the top of the column is broke.
on top of the column, down above the brake pedal is the ignition switch. it is held on by 2 bolts, if i remember correctly you need a 7/16 wrench. remove the switch and see if you can start and shut off the truck using a small screwdriver to work the switch. if everything works properly, the actuator is bad.
common problem point on the old body style trucks.
I had it running and it shut off ok. It was the second or third start that it did this.
I will do that. Thanks.
I will check that, but I think its something inside the cab. The guages and radio stayed on too.
That would cause every thing that mine is doing.
I'll check it. How much is it and how hard is it to change?
If your radio stayed on too, then its definately in your ignition switch or somewhere between the switch and the key cylinder. I can't think of anytihng else that could cause all of that.
