Wiring problem after engine swap.
Old May 3, 2010 | 10:37 PM
  #31
David85's Avatar
David85
1990 uses a speedometer cable. Check both ends at the transmission and the speedometer rear input to make sure its in all the way.
Old May 3, 2010 | 10:51 PM
  #32
bill11012's Avatar
bill11012
Modular motor junkie
I bet I just pulled the end loose.
So the VSS Is just for the RABS and CC?
Old May 3, 2010 | 11:07 PM
  #33
David85's Avatar
David85
For 1990 you have two speed sensors. The rear one on the differential is only for the RABS so even though I suspect its the same as the 92 up VSS (I think starmilt confirmed this once actually through the course of a rear axle swap), its only an ABS sensor for 91 and older. The forward sensor on the bottom end of the speedometer cable is for the cruise control and automatic transmission reference (if equipped).
basically 92 and up is a simplified design.
Old May 3, 2010 | 11:13 PM
  #34
bill11012's Avatar
bill11012
Ok, that makes sense. Thanks for all the help and info!
Old May 4, 2010 | 09:40 PM
  #35
bill11012's Avatar
bill11012
I looked and the speedo cable is tight on the trany end, it must be loose under the dash.
What do I take apart to get to it and what could I have broken?
The oil pressure gauge is not working. Where is the sending unit for it?
Old May 4, 2010 | 10:18 PM
  #36
David85's Avatar
David85
You will see a cable comming in either through the floor right next to the firewall seam or in through the firewall. If all thats happened is the cable came loose from the back of the cluster, you should be able to lay down with on the floor mat under the dash and reach up with your hand inside the dash from underneath to try and push the cable in all the way. Wiggle sideways a little as you try and press it in.
If that doesn't do it, then you might be better off trying to pull the cluster assembly and service it that way.
There is a small plastic clip that retains the cable in the back of the speedometer. To install, it should just snap in. To remove, there is a little trick to it:
Old May 4, 2010 | 10:26 PM
  #37
David85's Avatar
David85
Forgot to answer the sending unit question. Its located at the back of the engine behind the intake manifold. Its the only thing there that has a single wire coming out of it.
Old May 4, 2010 | 11:15 PM
  #38
bill11012's Avatar
bill11012
Thanks David. I will go out in the morning and see if I can fix both problems with that info.
Old May 6, 2010 | 06:36 PM
  #39
bill11012's Avatar
bill11012
I have done it every way I can think of, but can't find a way to get my hand back there.
Is pulling the cluster the only other option?
Old May 6, 2010 | 06:53 PM
  #40
johnboggs21's Avatar
johnboggs21
get a little kid with small hands
Old May 6, 2010 | 07:17 PM
  #41
bill11012's Avatar
bill11012
Worth a try.
Old May 8, 2010 | 09:30 PM
  #42
Dave Sponaugle's Avatar
Dave Sponaugle
On my 86 the only way to get to the speedo cable is pulling the cluster.
While you have it out, you can also clean the cluster light bulbs and wiring harness connections.
With my hands, even changing a couple of the light bulbs is easier with the cluster out.
Broken speedo cable, maybe.
Stripped or worn gears at the transmission/transfer case end, more likely.
Old May 9, 2010 | 01:50 PM
  #43
bill11012's Avatar
bill11012
I will pull the gears on the T case first then. It was fine, but I dropped the tranny and it pulled the cable tight. It has not worked sinse.
FORDMAN460ZACH
Oct 6, 2014 03:57 PM
28to4088broncoii
Bronco II
Apr 10, 2013 02:30 PM
pabear89
Dec 17, 2005 12:40 PM
Beast12
Electrical Systems/Wiring
Jul 30, 2004 10:16 PM
redwood
Jul 9, 2004 12:59 AM
