Oil?
Old May 8, 2010 | 02:28 PM
lowridaz22's Avatar
lowridaz22
Oil?
Picked up a very nice 1990 F-250 with a Banks 7.3! It runs very well after warm-up, but there's a little tick in the first few minutes of operation. I'm betting the car lot did a oil change and put in the wrong oil. I see tons of different kinds of oil for my truck so what do you use?
I've seen 15-40.... 5-40.... Oil specifically for turbo diesel.... What do you guys think.
Even if it's a sticky lifter, I don't know how long it's been ticking, and it runs / tows great! Is there a certain diesel oil that will quiet the lifter?
Old May 8, 2010 | 02:39 PM
Lazy K's Avatar
Lazy K
You will probably get as many different opinions as there are members but for what it is worth, I run Mobil Delvac 15w40. I use it in the truck and a couple other diesel engines and have had no problems with it.
Old May 8, 2010 | 02:58 PM
oreocreaming's Avatar
oreocreaming
i stick to 15w40. a lot of guys with newer engines are using the 5w for better fuel mileage. i say stick with the 15w40. chevron makes a great oil for a great price. i use valvoline diesel when it is on sale.
Old May 8, 2010 | 07:11 PM
kenpobuck's Avatar
kenpobuck
I use the motorcraft diesel 15-40. Wally world sells ir for $11.50 in the 5qaurt jug.
Old May 8, 2010 | 08:20 PM
rckslash2010's Avatar
rckslash2010
Rotela 15/40 T
I use that because that's what I figured was most common on this site.
Old May 9, 2010 | 02:03 AM
Dbailey's Avatar
Dbailey
Rotela is the only way to go.
Old May 9, 2010 | 02:40 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Delo 400 straight 30 ...
-Enjoy
fh : )_~
Old May 9, 2010 | 06:12 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
If the oil is rated for hd diesel engine then it is ok to use. Brands are a personal preference. The tick could be from a sticky injector. I add extra lube in the fuel as I had a tick and it went away after several tanks. Use it regulary in all the diesels on the farm and the engines on the older farm equipment runs better. They was manufactured in the days of high sulfur fuels.
Old May 9, 2010 | 06:53 AM
rckslash2010
I had a tick in my i.p once, it went away when I cut my muffler off.
Old May 9, 2010 | 10:26 AM
johnboggs21's Avatar
johnboggs21
Rotella T 15W-40 here
Old May 9, 2010 | 02:05 PM
fellro86's Avatar
fellro86
The newer engines are spec'd for the 5w-30 diesel oil, I won't run anything less than 15w-40 diesel spec on the older diesels.
KingCuda440
Mar 20, 2014 03:46 PM
zaaac
Jan 31, 2010 02:55 PM
SCWIDVICIOUS
Jun 30, 2006 05:44 PM
fordxfour87
Bronco II
31
Jun 22, 2006 11:37 PM
tombob
1978 - 1996 Big Bronco
Dec 13, 2002 07:54 AM
