Trailer Brake controller
Old Apr 29, 2010 | 06:08 PM
iduger's Avatar
iduger
Any one know how to reset tbc fault on monitor on dash. All systems work on controller just have that message to get rid of.
Old Apr 29, 2010 | 06:59 PM
iduger's Avatar
iduger
help
Is anybody out there?
Old Apr 29, 2010 | 07:11 PM
tex25025's Avatar
tex25025
Only way I know is with something like AutoEnginuity and clear the fault through that. I don't know of another way.
Old Apr 29, 2010 | 08:03 PM
rotun's Avatar
rotun
Reads ***** rules!
Are you plugged in while getting the code? Just asking as everything seemed to be working on mine but still had the fault. After searching for awhile I did find a wire disconnected on one of the brake solenoids. Hooked up wire and it went away.
Old Apr 29, 2010 | 08:12 PM
69cj's Avatar
69cj
Too my knowledge you need some sort of code reader to reset codes or disconnect batteries which is my last choice.
Old Apr 29, 2010 | 08:30 PM
droffan's Avatar
droffan
try gettin the manual online...
most manuals are avialabel there. google the manufacturer name and see what happens.
Old Apr 29, 2010 | 08:58 PM
rotun's Avatar
rotun
Reads ***** rules!
Old Apr 29, 2010 | 09:03 PM
bbier64's Avatar
bbier64
I have the tbc fault. I reset it with a scanner but it came right back. The potentiometer in the manual slider is bad. Have to wiggle it to make it work. The pressure transducer and automatic trailer braking work fine.
Old Apr 29, 2010 | 09:41 PM
iduger's Avatar
iduger
Im not hooked up to any trailer. The code just stays on the screen. Its the factory brake controller, sure would hate to take it to ford. Thanks for all your input this site rocks
Old Apr 30, 2010 | 09:54 AM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
What year/model truck. I know it's NOT the truck in your profile...No TCB in '97.
Have you looked to see if there is corrosion inside the 7-pin plug at the hitch? Many have had that happen. Open plug, clean connections and protect with dielectric grease.
Old Apr 30, 2010 | 07:20 PM
iduger's Avatar
iduger
Its an 05 model year.
njstevens
Oct 1, 2021 09:41 PM
JAZ8602
Sep 15, 2016 01:27 PM
srb1194
2009 - 2014 F150
Jun 13, 2016 04:43 PM
289 sprint
1966 - 1977 Early Broncos
Apr 9, 2015 08:45 PM
mrwrench
Oct 19, 2009 01:25 PM
