03 F250 PSD Filter
Old Apr 26, 2010 | 06:31 PM
jkoons's Avatar
jkoons
03 F250 PSD Filter
OK so the main frame fuel filter water drain rounded out,what's the best way to remove? Will replace with the newer type. Thanks Jerry
Old Apr 26, 2010 | 06:34 PM
bismic's Avatar
bismic
Some folks have had success w/ epoxy'ing an allen wrench in the rounded hole. Others have tried the "screw extractors".
utjer's Avatar
utjer
Some have used a sacraficial alan wrench with jb weld to get it out.
Old Apr 26, 2010 | 06:36 PM
JasonInBTR's Avatar
JasonInBTR
Probably a screw/bolt extractor. If you get a large enough one it may fit into the rounded out hole.
Jason
Old Apr 28, 2010 | 10:39 AM
jkoons's Avatar
jkoons
Got the old brass drain out, new plug is steel. A better ideal maybe. Thank Jerry
Old Apr 28, 2010 | 11:03 AM
nylyon's Avatar
nylyon
How did you get it out?
Old Apr 30, 2010 | 07:23 PM
jkoons's Avatar
jkoons
I have a set of extractor only around 1 1/2" long and you use 1/2" wrench on it,of course had to swing front drive shaft out of way so I could tape in with hammer. It was really tight should only be about finger tight.
