Problems
Old Apr 29, 2010 | 11:52 AM
dwilli's Avatar
dwilli
Problems
Just installed a high pressure oil pump and ipr valve solenoid and now I don't have any oil pressure. Therefore, truck will not start. Need help.
Old Apr 29, 2010 | 11:55 AM
riverrat41's Avatar
riverrat41
Welcome to FTE....Don't take this the wrong way.Did you fill the HPOP reservoir after installing?
Old Apr 29, 2010 | 12:01 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
I do think we need more info then that. Tell us what you did, how you did it, and all about what is happening while trying to start the truck. What truck do you have? Oil in the HPOP? Things like that.
Old Apr 29, 2010 | 12:43 PM
rat49f6's Avatar
rat49f6
Subcribing awaiting more info...
Old Apr 29, 2010 | 12:45 PM
dwilli's Avatar
dwilli
The reservoir is full of oil.
Old Apr 29, 2010 | 12:55 PM
Izzy351's Avatar
Izzy351
How long have you cranked and how do you know for sure you don't have HP oil? When I drained mine, it took several 10-15 second cranks to build up enough pressure to get id started.
Old Apr 29, 2010 | 12:56 PM
nhill2090's Avatar
nhill2090
how long did you crank it? IT may take a bit..
Old Apr 29, 2010 | 01:31 PM
rat49f6's Avatar
rat49f6
Is it a new pump? Rebulit?
Old Apr 29, 2010 | 01:42 PM
megawatt00's Avatar
megawatt00
I am wondering if that little ball bearing under the non serviceable plug is the culprit Jim
Old Apr 29, 2010 | 09:51 PM
rat49f6's Avatar
rat49f6
that's y I'm asking if it was new or rebuilt. If the ball bearing is on the wrong side of the non serviceable plug the op would hear a noise that sounds like a leaky tire, after cranking.
olfordsnstone
Jan 21, 2014 02:34 PM
cornfeed
2004 - 2008 F150
Dec 12, 2012 08:14 AM
zachsherman88
16
Mar 26, 2009 10:48 PM
jdwillen
Oct 14, 2005 09:21 PM
jeepin
Jul 10, 2003 01:06 AM
