Oil Pressure
Old Mar 13, 2009 | 03:08 PM
zachsherman88's Avatar
zachsherman88
Oil Pressure
are there any ways to increase the oil pressure in a 400? other than a higher weight oil?
Old Mar 13, 2009 | 03:38 PM
hollenjoe's Avatar
hollenjoe
High volume oil pump, theres an increase in 25%
Old Mar 14, 2009 | 08:14 AM
Mud Rat's Avatar
Mud Rat
Modify your oil pump discharge circuit.
Old Mar 16, 2009 | 07:16 AM
MBDiagMan's Avatar
MBDiagMan
We could help you a lot more if you would elaborate. Are you building an engine and want to improve the lubrication system, or are you talking about an older engine with low oil pressure?
Old Mar 20, 2009 | 10:27 PM
zachsherman88
its an older engine and am just trying to improve the oil pressure any way i can im using 10w-40 right now and when i get off the highway oil pressure drops below normal operating pressure i wish i could tell you the exact pressure but all i have to go off of is my dash gauge ive already replaced my oil pump and sending unit however i havent gotten a hgih volume pump i will try that
Old Mar 20, 2009 | 11:18 PM
Jermafenser's Avatar
Jermafenser
Oh, here we go...depending on 30 years old factory gauge.
It's nothing more than a variable idiot light!
Get a mechanical gauge on it before you throw any green on it!
Old Mar 21, 2009 | 10:01 AM
JBradley500's Avatar
JBradley500
if its above 15 psi... i wouldn't worry about it on a stock 400.
Old Mar 21, 2009 | 01:10 PM
hollenjoe's Avatar
hollenjoe
Ive heard around here the general rule is 10 psi for every 1000 rpms, so in iddle (600 rpms - 800rpms) 6 or 8 psi would be enough....
Old Mar 21, 2009 | 02:25 PM
grclark351's Avatar
grclark351
you should've tried the high volume oil pump and instead of a standard but that was then. sounds like it's time for main and rod bearings. if the crank is original and still standard size you can get +.001" mains. the front cam bearing also plays a role in oil pressure. if it's worn out maybe you can get by with just replacing the front cam bearing but it important that it gets installed right, .003" back from the edge of the block.
as mentioned you can get by for some time with marginal pressure and thicker oil. i had a car i'd mix oil to get 'medium heavy', like 3 quarts 10-40 and 2 quarts 20-50
Old Mar 25, 2009 | 06:47 PM
zachsherman88
alright i installed a mechanical gauge and at idle it gets to about 5 psi and there is a knocking noise also i have dual exhaust and there is white smoke coming out the ride exhaust pipe i bought a new oil pump new rod and main bearings and a rear oil seal all will be installed tommorow the bearings i bought are just stock size atm should i plan on .001 bearings instead?
zachsherman88
forgot to mention that on cold start psi is at 45
Old Mar 25, 2009 | 07:56 PM
grclark351's Avatar
grclark351
sounds like it's time for head gaskets too. technically the crank should be measured before throwing +.001" bearings at it, it's your call...
standard or high volume pump?
Old Mar 26, 2009 | 10:00 AM
zachsherman88
high volume and its got a brand new head gasket already as i was working on the heads before this happened
Old Mar 26, 2009 | 10:07 AM
MBDiagMan's Avatar
MBDiagMan
clark is right, .001 under bearings on a worn crank is NOT a good plan. Crank pins almost always wear flat, or egg shaped. They don't wear the same all the way around.
Yes, with white smoke you need to do some more analysis on this engine. A quick and easy place to start would be to pressure check the cooling system.
Old Mar 26, 2009 | 10:29 PM
zachsherman88
also when i got the new head gaskets there was a coolant hole that the new gasket didnt have a hole for but i didnt think it would be a problem since the old gasket was the same way should i go back in there and cut out the holes and reseal the heads?
