I was wondering if anyone knows should a prodigy brake controler be sending any power to the brake pin (blue wire) ant the 7 way plug with out the brajes being applied or anything hooked up. I tested it today and there is a constant 0.06V to the blue wire. Is this right?
I don't have a Prodigy, but you are most likely reading the signal voltage telling the controller you the seven pin plugged in. It tells you if you are unplugged, right?
No I put a volt meter to the back of the truck to test for power. My friend has a P3 I put it in did the same test wich was constant 0.03 and every 8-10 seconds it would pulse to 0.15 then back to 0.03. It seem like my truck it working to hard to pull my little travel trailer. I had all brakes and bearing checked, they were all good. Juat trieng to narrow what could be wrong.
nothing but the two lights that mean power and brake boost. I called tech support couple days ago and was told the prodigy would send a pulse every 8-10 seconds it is checking to make sure trailer it hooked up. They did not say constant voltage. I will call again tommorrow just thought I would ask tonight I leave on a camping trip with the trailer tommorrow.
