Brake controller - blue wire?
Old Oct 16, 2005 | 07:57 AM
trike1946's Avatar
trike1946
Question Brake controller - blue wire?
Hi, I know the blue wire from the brake controller goes to the rear plug to work the trailer brakes. My question is should there be power in the blue wire when the truck is on but not pushing the brakes? And if so how much? The test light does go on now, but I haven't checked it with a meter to see how much. And I assume it should increase when I push the brake pedal. How much? Thanks for any help.
Old Oct 16, 2005 | 08:14 AM
EPNCSU2006's Avatar
EPNCSU2006
I think there will be voltage present, at least with a Tekonsha controller (and probably others as well). The brake controller uses this to detect that a trailer is plugged into the truck and that voltage should go away when a trailer is connected.
XSleeper
Electrical Systems/Wiring
Mar 14, 2020 09:10 PM
maddmatt02
Dec 4, 2017 08:00 AM
Brian Dale
Oct 19, 2016 09:42 AM
jusjoe
All Things Towing
19
Jun 21, 2015 05:41 PM
bashby
All Things Towing
Nov 8, 2011 01:00 PM
