Just wondering if anyone has put a subwoofer in a 2010 super duty cc?
I was thinking about using a Bazooka amplified 6 inch. Has anyone used a Bazooka? If so did it sound good? There is not much room to put anything behind the rear seat. Any input will be welcome.
Thanks for the pictures. One of the problems I am having is that there is a shoulder harness mount on the back wall on the 2010 sdcc. I would have to remove the shoulder belt to mount a sub box that big. I am trying to find a way to install a sub without removing the shoulder harness.
Can you not find a stock 2011 subwoofer setup and add it in? I know you can supply audio do that amp with a RCA cable same as a aftermarket. Im sure we will have people pulling them out soon enough.
Thanks for the information. I am going to give supercrew sound a call. It looks like they may have what I need. Installing a sub in a box would most likely sound better than a 6 inch Bazooka.
I been wondering about fitting a sub to my CC its the first non reg cab truck I have had. I fit (barely) an 18" JL in my regular cab F150 youd think the big bad 350 would have more room but it appears to be much less space for subs thats for sure.
