Sponsored by: Real Truck
06 250 electric brake controller....HELP
Old Apr 29, 2010 | 08:35 PM
TractorM3's Avatar
TractorM3
so i have to tow a huge trailer tomorrow and need brakes. I had bought the brake controller with the ford harness thinking it would plug right in. well it didnt. I found four wires (blue, red, white, black) hanging out under the hood just to the right of the vaccum booster for the brakes. so i figured it had a brake controller at one time and i just hook into these wires and im golden!
well i hooked into them and nothing! no battery power, no ground, and no brake power. i cant really test the blue one.
so i checked all my fuses and such with little luck
any ideas?
i got my meter on it now and am trying anything
Old Apr 29, 2010 | 08:54 PM
Hummer1's Avatar
Hummer1
The 4 wires left of the brake booster are spare wires that just go thru the firewall and come out close to the steering post inside the truck.I have the built inn controller so I dont know if your truck has a plug under the dash to hook up the brake controller.I would call your Ford dealer.
Old Apr 30, 2010 | 12:58 AM
redford's Avatar
redford
FTE Leadership Emeritus
What you found are called the "blunt cut wires." These are just wires that pass through the firewall for hooking up accessories.
Somewhere under your dashboard will be a plug that interfaces with the controller you purchased. I also have the factory TBC, so I can't help you with the location.
Old Apr 30, 2010 | 06:56 AM
firemanpat29's Avatar
firemanpat29
x 3 what they said
Old Apr 30, 2010 | 09:46 AM
BigPigDaddy's Avatar
BigPigDaddy
The below link tells you where your factory plug is.
Trailer Hitch Instructions For DrawTite, Reese, Hidden Hitch & More - etrailer.com
Hope you get this in time.
Frankievespa
Apr 11, 2011 09:56 PM
apbtpetey
Electrical Systems/Wiring
13
Oct 25, 2010 10:22 PM
dyhrdford
All Things Towing
21
Aug 14, 2010 07:12 PM
tettnanger7
All Things Towing
Sep 21, 2009 03:04 PM
Sycostang67
All Things Towing
Mar 12, 2005 12:56 PM
