Sponsored by: Innova
Do I Need an Amp?
Old Jun 12, 2014 | 07:32 PM
RedRaider15's Avatar
RedRaider15
Exclamation Do I Need an Amp?
I will be getting four Pioneer TS-A6885R four-way speakers. I currently have a Bazooka Bass Tube installed and an aftermarket stereo with 17 watts RMS of power. The speakers need 5-60 watts of RMS power. Do I need an amp? If so, how big? Also, my stereo has six Preamp outputs, two of which I am using for my subwoofer. The others are labeled Front and Rear outputs, so what would I use to for the amp?
Old Jun 25, 2014 | 09:36 AM
hotrod351's Avatar
hotrod351
i used the front. connected to a amp, for my door speakers, the rear, connected to another amp, for two 6" X 9" behind my seat and my sub out, connected to yet another amp, for my two 8" subs. but yes a amp would make a difference. so if all your going to run is your sub and door speakers then the sub out and the front out.
Old Jun 25, 2014 | 12:03 PM
Superduty71's Avatar
Superduty71
Trailering
Do you need an Amp? No…
Will an Amp help? Absolutely<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
It really comes down to what you are looking for / expecting & of course budget, so to clarify some of your questions.<o></o>
<o> </o>
I will assume you are placing (1) pair of the speakers in the front doors & the other pair in the rear. If this is the case then I would look at a 4-channel Amp with front & rear pre-amp inputs. Connect the Front & Rear outputs from your receiver to the input on the amp; this will allow you to still use the fade control from front to rear. <o></o>
<o> </o>
How big of an amp? This is a budget, brand, power question -(there are a billion answers – kind of a Pandora’s Box) but you should be able to purchase something in the 45w RMS per channel range fairly inexpensively. <o></o>
Just remember with an amp comes the added cost of an amp install kit (power / ground wire, fusing, RCA inner-connects, speaker cable, etc)
Old Jun 28, 2014 | 11:07 AM
01fordbus's Avatar
01fordbus
I would recommend a nice 4 channel amp just to give the extra bump
But it wouldn't be required
Patatoe1
16
Feb 20, 2005 10:00 AM
2004lariat
Sep 10, 2004 12:59 PM
FordnKC
Jul 5, 2004 05:13 PM
awf-150
May 18, 2004 09:51 AM
jeremyd72
Jan 9, 2004 09:23 AM
