PTO question
Old Apr 27, 2010 | 04:28 PM
EpicCowlick's Avatar
EpicCowlick
PTO question
On my order, I did not take the PTO prep option because I assumed it would be easy to add if I ever needed one. Turns out I may need one and I need to know if the PTO prep must be added from the factory or if it can be added onto the trans after delivery. I heard today that adding a PTO to a non-prepped trans is very expensive. A cab-off and trans case replacement. Does anyone know if this is the case?
I can still change my order since I don't have a VIN yet.
Old Apr 27, 2010 | 07:09 PM
FireMe's Avatar
FireMe
Looking through Ford's material this is not a "bolt on" option, it looks like you will need a case and numerous internal components. Adding in about 12 hours of labor for teardown and assembly and just taking a rough guess at parts pricing from experience, I can see this project easily exceeding $3,000. Keep in mind that parts are sometimes impossible to get for new releases and you may be forced to buy a new trans assembly instead. I can't even begin to guess how much that would be.
If I were you, I'd change my order and avoid a possible very big headache.
Jay
Old Apr 28, 2010 | 05:22 PM
EpicCowlick
Confirmed that it is a big dang deal to add PTO after the fact. Lucky for me, my order could still be changed. That's one good thing coming from the parts delays..
$230 option from the factory. $3,000 if you wait to add later. No brainer.
If anyone thinks they may want to add a PTO powered device, they better consider it before they order their truck.
Diesel_Brad
Jan 6, 2017 09:09 AM
coolidge54
Oct 31, 2016 02:53 PM
snakedoc
18
Dec 21, 2012 08:22 PM
renaissanceman
Feb 2, 2005 05:19 PM
marcveinotte
Nov 19, 2004 09:05 AM
