6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
another breakdown tonight...
Old Apr 25, 2010 | 09:22 PM
weyland426's Avatar
weyland426
this time was on the interstate and boy was it busy out there today. was cruising along at 75mph and noticed the regen cycle start. immediately, the message center changed to "safely stop now". i had no power at all and coasted to the shoulder before the engine died. an attempt to restart resulted in no more than a beeping from dash. last time i went into limp mode and could idle to the dealer...this time was a hundred dollar towing tab. it's now sitting on the dealer lot where the last fix of egr and radiator replacement took them better than a week. any idea what this might be?
Old Apr 26, 2010 | 05:22 AM
senix's Avatar
senix
Just from your discription I would say something to do with the emissions. DPF or sensor related.
How come it cost you for the tow. Arn't you still under warranty?
Old Apr 26, 2010 | 05:37 AM
ruschejj's Avatar
ruschejj
I hate to say it but maybe you should buy a code reader. Then we all would know exactly what is going on.
My Edge Insight has temp warnings and stores codes, allows me to read them. I have been lucky enough to not need it tho.
Any smoke? White, grey, black?
Probably a condition of high temperature in the EGR, turbo, or exhaust system.
Old Apr 26, 2010 | 06:54 AM
weyland426's Avatar
weyland426
just got off the phone with the service tech...said it was likely an exhaust sensor thinking the system was overheating. bad thing is it will be a few days for him to even pull it in the garage to read the code....i feel like less of a man driving my wife's minivan. regarding the towing bill...i fully intend to ask ford to cover that if the problem is covered under warranty. thanks.
Old Apr 26, 2010 | 07:07 AM
senix's Avatar
senix
A code reader with the Ford codes would be a good investment. I can read and clear them with my Banks IQ. But I have never had any since the first issues I had when I bought the truck. Problem free for about 30K.
Old Apr 26, 2010 | 07:37 AM
weyland426's Avatar
weyland426
forgive my ignorance, but would "clearing a code" actually reset a sensor and allow the engine to run again? if so, agreed that it would be worth the money...especially since i just ordered a rental car for the week at $200.
Old Apr 26, 2010 | 08:19 AM
senix's Avatar
senix
It possibly would of in this case..but for how long? Maybe enough to get it home. Hard to say. You would need to be really careful and read the code on the issue. Obviously some codes like a eng temp or no oil press I would really investigate prior to clearing the codes.
Old Apr 26, 2010 | 08:27 AM
Tom's Avatar
Tom
I'm not sure, but I doubt clearing the codes would let the engine run again. And if it did, it would likely sense the same fault right away and shut down again.
Even if it could, I'm not sure you would want it to. It's only supposed to force a shut down to protect itself. For example, if it were to shut down due to dangerously high EGTs, you would NOT want to start it again. Doing so could destroy your engine!
And Scott, oil pressure isn't monitored by the PCM. Kind of scary, with nothing monitoring something that's that important!
Old Apr 26, 2010 | 09:02 AM
senix's Avatar
senix
Tom, maybe it is just eng temp and coolant temps monitored. That is all I get with my IQ.
ArtsBest
2009 - 2014 F150
Feb 1, 2013 05:08 PM
Kory Landry
6.7L Power Stroke Diesel
May 26, 2012 07:16 AM
ddicanada
2009 - 2014 F150
Dec 17, 2010 11:23 PM
RRranch
Feb 19, 2009 10:20 AM
Billyclub
15
Apr 23, 2006 01:31 AM
