Starting problem
Old Apr 20, 2010 | 07:57 PM
jelzy's Avatar
jelzy
Starting problem
Installed new stage 1 injectors. Now the truck will not start unless you remove the fuel line and purge it until fuel comes out the reconnect and it runs for about 30 +- sec, Any clues what the problem is?
1997 7.3 power stroke/
Old Apr 20, 2010 | 08:01 PM
fordpride's Avatar
fordpride
sounds like air in the fuel rails in the head
Old Apr 20, 2010 | 08:09 PM
jelzy's Avatar
jelzy
How do you bleed the air out?
Old Apr 20, 2010 | 08:13 PM
Hussler's Avatar
Hussler
What fuel line are you disconnecting and purging?
Old Apr 20, 2010 | 08:18 PM
jelzy's Avatar
jelzy
The main line in the front.
Old Apr 20, 2010 | 08:44 PM
yoslick's Avatar
yoslick
What kind of pressure are you showing at the schraeder valve?, Sounds like pump trouble... How olds the pump?
AFoster1025
Oct 25, 2010 05:48 PM
86bluebronco
1978 - 1996 Big Bronco
17
Jun 24, 2010 09:39 AM
BanjoJim
Aug 20, 2007 10:10 PM
dashark
Jan 14, 2005 11:20 PM
dieselpup
Jan 5, 2005 07:57 PM
