any help. 1997 7.3 power stroke diesel, starts with starting fluid only. will not run on it's own. has 70lbs fuel pressure, fuel not going to cylinders. thanks
First off welcome to the forum. And secondly, cause I don't ike to see anyone get hurt please, no starting fluid on trucks with glow plugs. It tends to have an explosive effect. Your problem could be a number of things. One thing to check is if your tach is registering while cranking. If not the cam sensor is a likley culprit. Does the truck smoke while cranking?? More info will be very helpful
hey, there's is no smoke while cranking, no rpm's while cranking, injector balance tested ok with snap on scan tool. check engine light came on for a brief second when the key is turned. thanks for any help you can give.
