Sponsored by: Real Truck
F650 Lower Dash
Old May 12, 2010 | 05:25 PM
  #46
beemr's Avatar
beemr
How are you putting the "grain pattern" into the fiberglass?
I made a holder for the brake controller that looks built in for those that are interested. it is for the controller pictured above.
I will post pictures later this week.
Old May 12, 2010 | 06:15 PM
  #47
TennesseeMustangPerf's Avatar
Originally Posted by grec-o-face
What about a place to mount a brake controller?
I thought about that, matter of fact, I was going to do this for my Tekonsha, however there are a few problems with this. First, some of the aftermarket controllers like my P3 have a hang down style override that would prevent an opening for the controller to be installed. Secondly, the different styles of controllers and mounts make it impossible to make one specifically for each controller. Thirdly, the location of the pod would require the driver to lean over ans stretch should they have to use the override in the event of an emergency, thus making for an unsafe position. Good idea though, just not practical for this pod.
Old May 12, 2010 | 06:18 PM
  #48
I use very well trained midget termites that eat tiny veins into the top layer only. They cost a fortune, but are worth the price.
I created a technique to put a grain pattern on things such as this several years ago. Once the plug is done and the grain put in, I will cast a mold and will be able to mass produce the part.
Old May 12, 2010 | 08:49 PM
  #49
beemr's Avatar
beemr
What's the technique...saran wrap pressed over a wet coat of primer?
My pod is for your controller...works perfectly on my stock '04 dash just below the "cubbyhole" opening.
It is basicaly in the same position as yours, and would adapt perfectly on the bottom of your dash piece.
Old May 12, 2010 | 09:59 PM
  #50
No, but close. I have used that technique however to make the grain pattern on other things.
Do you have some pics of the pod? That might be something that would be fairly simple to adapt. Still scares me in case of need to override the controller having the unit placed away from the driver's basic range, but I will have to experiment with it.
Old May 13, 2010 | 03:36 PM
  #51
beemr's Avatar
beemr
How do I insert pictures here?
Old May 13, 2010 | 03:51 PM
  #52
beemr's Avatar
beemr
...let's see if these show up...
Old May 13, 2010 | 03:53 PM
  #53
beemr's Avatar
beemr
Old May 13, 2010 | 03:56 PM
  #54
beemr's Avatar
beemr
Old May 13, 2010 | 03:57 PM
  #55
beemr's Avatar
beemr
Old May 13, 2010 | 03:59 PM
  #56
beemr's Avatar
beemr
Old May 13, 2010 | 04:00 PM
  #57
beemr's Avatar
beemr
Old May 13, 2010 | 04:01 PM
  #58
beemr's Avatar
beemr
Old May 13, 2010 | 09:04 PM
  #59
Problem is that my pod actually has the shape of the trash bag hook and goes there in replacement of the hook piece. That would put the TB controller on the passenger side of the truck, and possibly in a dangerous place if the driver needed to override the TB in an emergency situation.
Old May 13, 2010 | 09:19 PM
  #60
Here are the latest pics of the duckfoot. I have added the vinyl texture and painted it to match. Now I just have to cut the switch holes out.
Still needs a little tweaking, but not bad so far, I recon.
