Outside Temperature / Degree Reading Incorrect
Old Apr 20, 2010 | 09:56 AM
Kid Fresh's Avatar
Kid Fresh
Sup All,
Have a 05 F-150 FX4 (55k) and the "Outside Temperature" reading is always displaying over 100 + degrees, varies on the true outside temperature and can range from 100-1xx degrees.
** This is on the right side of the MPH gauge cluster, at the bottom; with the "compass" displaying the direction you are traveling (N, S, NE, etc.). The Compass IS functioning correctly.
It's minor / cosmetic to me, but figured I'd ask, might be an easy fix?
Did a thread & Google search, with no luck.
I noticed a tiny black square attached to the windshield with the rear view mirror........is that the sensor?
Thanks!
Old Apr 20, 2010 | 12:29 PM
Gearbanger 101's Avatar
Gearbanger 101
Does it fluctuate different temperatures when you’re parked and when driving, or is it always high?
Mine starts to climb (sometimes as much as 15C) if I'm parked in one spot too long, without airflow traveling through the front grill. I blame it on heat soak. I may look into attempting to relocate the sensor to move it further away from engine heat.
Old Apr 20, 2010 | 05:40 PM
1bad67sbf's Avatar
1bad67sbf
or see if the sensor has broke away and is near the motor.
Old Apr 20, 2010 | 06:49 PM
Still Smoking's Avatar
Still Smoking
Mine did that too. Wasnt as high but it was in the negatives. It was a bad sensor. I had it fixed under warranty.
Old Apr 20, 2010 | 08:13 PM
Kid Fresh's Avatar
Kid Fresh
So where exactly is the "sensor" located, in the engine?
Is it a part that can be replaced easily?
Old Apr 20, 2010 | 08:34 PM
Still Smoking
I had it replaced under warranty. If I remeber right the guy said its the sensor thats right behind the grill. I think its the one thats infront of the radiator. Could be wrong though. He did say it was easy but since it wasnt going to cost me anything they did it.
Old Apr 20, 2010 | 10:03 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
Hes right
Its in the center bracket in front of rad its the top one has a point on it the outher sensor is the air bags
Old Apr 21, 2010 | 12:08 AM
moto57's Avatar
moto57
Originally Posted by 2004 xlt 5.4
Hes right
Remove that top plastic panel that cover the gap between the grill and top of radiator, it's right underneath that panel.
Ambient air sensor
Old Apr 21, 2010 | 07:33 AM
Kid Fresh's Avatar
Kid Fresh
Ambient air sensor
Excellent, I'll call the dealership today and see if they have it in stock and pop the hood after work today, looks pretty easy removing / replacing the part.......thanks for the help!
Old Apr 21, 2010 | 05:43 PM
DashTrash's Avatar
DashTrash
Had my F-150 for over 5 years now and that temp. has never displayed correctly. If it's hot out, the sensor reads cold (20-30 degrees colder), if it's cold out, the sensor reads hot (10-30 degrees higher).
Hasn't seemed to affect anything.
Old May 20, 2010 | 03:25 PM
Kid Fresh's Avatar
Kid Fresh
Finally got around to locating the sensor, can't miss it, right in front of the radiator. BUT.......the bugger won't budge!!
It appears to be "clipped" in (snap on both sides), and I can't get it out.
Any suggestions on how, don't want to break the hook that's holding it to the frame.
Old May 20, 2010 | 09:20 PM
moto57's Avatar
moto57
On my 2001, I unscrewed the metal bracket from the frame with the sensor still attached. Then I could remove the sensor from the bracket. Made it much easier.
txsd
Aug 31, 2021 09:19 AM
imprezdcrew
Jan 25, 2013 05:08 AM
BradO66
2009 - 2014 F150
Nov 15, 2010 07:16 PM
bamawig
Jun 22, 2010 08:07 PM
pukemon
2004 - 2008 F150
33
Sep 12, 2009 05:35 AM
