Inaccurate Outside Temperature Display
Old May 8, 2017 | 07:28 PM
txsd's Avatar
txsd
Does anyone else have an outside temperature display that shows 5 to 10 degrees higher than actual temperature?
Old May 8, 2017 | 08:15 PM
wb6anp's Avatar
wb6anp
None of the outside temp displays have been accurate on any of my cars, as most are mounted low on the front frame so they get the heat form the road as well as radiated heat from the radiators, not sure where they are on the '17 yet.
Old May 8, 2017 | 08:26 PM
RubyRed350Platinum's Avatar
RubyRed350Platinum
I also hate the fact that if you idle the truck the temp stays where it was when you park. So in ND it may read 25 in the morning. But still show 25 at 5pm when it is 75 if the truck hasn't moved a long distance.
Old May 8, 2017 | 08:55 PM
bridge's Avatar
bridge
Sick 'n Tired
It's on the underside of the passenger rearview mirror. Metal objects gain heat, so if it's day time (or a warm evening) and the truck is parked, the reading will be high until you start driving.
Old May 9, 2017 | 09:35 AM
troverman's Avatar
troverman
I think the Super Duty has one of the best locations for the outside temp probe of any vehicle. It is high enough off the ground to not be affected much by heat radiating from the pavement, and away from the vehicle enough (mirrors extended) to not be as affected by heat radiating off the vehicle. Note that aluminum bodywork gains and loses heat faster than traditional steel. Additionally, but not locating the sensor in the grille or bumper area like most vehicles, the temp is not affected by heat soak when the vehicle is parked.
I was quite surprised to find out Ford was locating the temp probe here on both the previous generation and the 2017 trucks, since it is definitely more costly to locate here vs in the grille area. Some very cheap vehicles actually use the IAT probe in the plastic air intake to display ambient temp.
I find my Super Duty temp to start off much more accurate than my dad's 2016 F-150 (with the temp sensor located in a traditional spot).
Old Aug 31, 2021 | 07:40 AM
CHUCKJF3's Avatar
CHUCKJF3
EXT TEMP GAUGE STUCK AT 190 ITS HOT OUTSIDE TODAY
ANY IDEAS WHY 2013 FORD F 150 XLT EXT READ OUT IS IN THE RADIO WAS STUCK AT 88 HAD TO DISCONECT THE BATTERY NOW IT READS 190 ANU IDEAS ANYONE. DO NOT SEE ANY PREFORMACE ISSUES JUST WONDERING WHY AND IS IT A FAIRLY AN EASY INEXPISIVE FIX
Old Aug 31, 2021 | 07:43 AM
Mlarv's Avatar
Mlarv
The 2013 F150 temp sensor is located behind the grill.
You must have done a search on this forum then posted this question. This is the newer Super Duty side of the house. There is a F150 explicit forum here also that you will get better answers from.
Old Aug 31, 2021 | 09:19 AM
4wd6.7L's Avatar
4wd6.7L
Check this out- https://www.ford-trucks.com/forums/forum193/
Phx Raven
Feb 20, 2021 06:24 PM
jfralph
6.7L Power Stroke Diesel
Feb 11, 2014 01:54 PM
scottswierenga
Dec 7, 2013 07:08 PM
bcaughhorn
Dec 1, 2010 10:14 AM
HappyJack
Kansas Chapter
Jan 25, 2008 08:26 PM
