Help Me Go Lower
Old Apr 20, 2010 | 11:23 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Originally Posted by stylin86f150
It is a coiled front end and would that adjusting really get it a little bit lower?
Yes, And I'll try to explain how to do it as it was explained to me...
I have never tried this myself, however it was explained to me by a gent that works for a local spring shop.
It is not an exact method for the shorter the spring the higher the spring rate becomes thus less compression... There is a formula that accounts for the spring rate etc... I do not know it.
So sneak up on it ... Go to far and you'll be replacing springs.
Measure the Compressed Spring Height in truck. (Between upper and lower spring perches)
Jack up front.
Pull springs.
Adjust Camber to full positive.
Adjust jack height to correct camber.
Measure Desired Compressed Spring Height. (Between upper and lower spring perches)
Measure Free Spring Height.
Spring Compression = Free Spring Height - Compressed Spring Height.
Final Spring Height = Desired Compressed Spring Height + Spring Compression.
Hopefully I got that right!
-Enjoy
fh : )_~
Old Apr 20, 2010 | 02:21 PM
stylin86f150's Avatar
stylin86f150
ok thanks alot for explaining it. any idea of how low it could bring me?
Old Apr 20, 2010 | 10:06 PM
Festus Hagen
Methanoholic
Depends on how far the camber adjustment is to the negative side.
The more positive camber you can gain the lower it can go...
You do realize that any lowering of a vehicle throws the front end geometry right out the window, Unless the geometry is lowered with it.
-Enjoy
fh : )_~
Old Apr 21, 2010 | 10:05 AM
stylin86f150
-Enjoy
fh : )_~
Yea i know that. But i found out that my camber is as far as i can go meaning my truck is as low as it can go without changing the front end.
hotrod351
16
Sep 12, 2014 10:59 AM
bigbadbob17
16
Apr 27, 2014 07:36 PM
OneSweet81
Aftermarket Products
Aug 15, 2004 07:15 PM
first time 4x4
Mar 12, 2003 06:03 PM
Guy
Feb 3, 2001 06:23 AM
