Help Me Go Lower
Old Apr 18, 2010 | 08:18 PM
stylin86f150's Avatar
stylin86f150
Help Me Go Lower
Hey all this is short and sweet for me that is. I want to know how to go lower. I already have the drop ibeams in the front which gave me 3" and I took out this piece under my front springs which gave me about another inch. Please dont suggest airbags there just too expensive. The rear is really no problem because I can just put more blocks on the leaf springs. Thanks all
Old Apr 18, 2010 | 09:50 PM
newrider3's Avatar
newrider3
CVPI front clip swap. See https://www.ford-trucks.com/forums/7...o-67-f100.html
Old Apr 19, 2010 | 12:30 PM
stylin86f150
Originally Posted by newrider3
Thats a little too much for me to do right now. I was hoping for something less complicated. I knew people also put in mustang front ends too, to get a better ride height.
Old Apr 19, 2010 | 12:46 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Sounds like your only option, short of a total suspension swap, is drop spindles. I'm not sure if the drop spindles can work along with drop I-beams, so do research before jumping in full speed.
Old Apr 19, 2010 | 12:56 PM
Chitownhillbilly's Avatar
Chitownhillbilly
I don't think you can get drop spindles, thats the purpose of the beams.
Anything past the 4 inches you've already achieved is going to be complicated and expensive.
Plus you already have the 2nd best looking truck on this site, why change it??
Old Apr 19, 2010 | 12:58 PM
stylin86f150
haha thanks but I still would like to go lower just for the fact of getting it as low as possible. But Im not going to spend a arm and a leg for it I just was'nt sure if I could get smaller shocks or something. Thanks tho
Old Apr 19, 2010 | 01:14 PM
Chitownhillbilly
Are your shocks stock length? Are the bottomed out? The shocks won't keep ya from going lower unless they're bottomed out. Did you put shorter springs on?
Old Apr 19, 2010 | 01:34 PM
stylin86f150
opps i meant to say springs. yea my shocks are lowering shocks. but do they sell shorter springs. and to bring up something else can I get it adjusted anymore if i go lower?
Old Apr 19, 2010 | 01:53 PM
Rogue_Wulff
There may be enough adjustment left to allow you to drop it another 1-2". You would need to consult an alignment shop to confirm whether you have additional camber adjustment left.
I've seen references to drop spindles for these trucks, so I'm sure *someone* offers them. Since I'm not really "into" lowering trucks, I don't have any info about parts or sources. I respect a properly lowered vehicle for what it is, a statement of individuality.
My RX7 is dropped about 1.5" front and 2" rear thru the use of Ground Control coilover front, and special GC Eibach rear springs. It wasn't done just for looks, it was done to improve handling, which it has done nicely.
Old Apr 19, 2010 | 02:06 PM
stylin86f150
well could someone help me find the spindles rogue_Wulff is talking about because I cant find any.
Old Apr 19, 2010 | 02:44 PM
Chitownhillbilly
I really don't think anyone makes them. Maybe they did back in the day, but now the only Drop spindles you see for Fords in 1997 or later F150 or 1998 later Rangers. Which coincidentally is when both went away from Twin I beam front ends.
Old Apr 19, 2010 | 06:06 PM
Rogue_Wulff
It's quite possible that they are no longer available. That's not to say that you can't find some old stock somewhere, or even some used.
Old Apr 19, 2010 | 10:14 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Is it coil or leaf sprung up front ...
To get a little more, Simply stated,
Adjust camber to full positive, adjust springs/ride height to proper camber.
-Enjoy
fh : )_~
Old Apr 20, 2010 | 10:02 AM
stylin86f150
It is a coiled front end and would that adjusting really get it a little bit lower?
Old Apr 20, 2010 | 10:53 AM
Chitownhillbilly
Yes, because what Festus is recommending would allow you the shortest possible coil springs.
