Random engine dying
Old Apr 16, 2010 | 10:31 PM
physicsguy11's Avatar
physicsguy11
Question Random engine dying
Twice today my engine just died while driving.
It was a few minutes after starting both times. It was like all gas was cut off, and it just went to sleep. It then started right up again, with no problems, and much easier than usual.
It usually stutters a little bit when I turn the key off, and takes a few cranks of the starter to get going. It almost seems like an electrical issue that kicks in when a certain engine temperature is reached.
Anyone have similar experiences and/or know a solution?
Old Apr 16, 2010 | 10:36 PM
4x4cody's Avatar
4x4cody
this recently happened to me...
pulled my sending unit out of my saddle tank, the one behind seat..
and i had unnecessary hoses floating to the top, pushed them back down and made it home.. idk if this may be ur problem but it was mine.. iam a lil iffy on using that tank so i use my rear tank..
Old Apr 16, 2010 | 10:38 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Classic Ignition module and/ or distributor pick-up failing.
Josh
Old Apr 16, 2010 | 10:48 PM
montana_highboy's Avatar
montana_highboy
ICM, if you own one of theses trucks long enough you'll learn to keep a spare ICM under the seat, it's like "life support" for these trucks.
Old Apr 16, 2010 | 10:55 PM
77460f150's Avatar
77460f150
Yea, what they said. Replace the ICM (ignition control module) on the left inner fender and drive on!! -Ed
Old Apr 16, 2010 | 11:20 PM
physicsguy11
Lol... funny that you should mention the ICM.... I just bought a "new" one a couple months ago. I have no idea how new it is.. bought it from schucks... dont know if they remanufacture these or what. anyway... is there a way to diagnose if any of these parts you all mentioned are failing?
Old Apr 16, 2010 | 11:36 PM
Bullitt390's Avatar
Bullitt390
Even brand new units are junk. You're best bet is a genuine Motorcraft module.
I suggest changing the pick-up in the distributor as well. They generate the same symptoms unfortunately.
Josh
Old Apr 16, 2010 | 11:57 PM
4x4cody's Avatar
4x4cody
i never thought about the icm before but i think just in case to be safe iam gunna go to a junkyard and grab a couple for spares..
Old Apr 17, 2010 | 06:48 PM
physicsguy11
while tooling around under the hood trying to find if there was anything else i wanted to buy while at the store for the ICM, i noticed that the clip assembly that goes onto the ignition coil was a little loose. I started the truck up, wiggled the clip around, and the truck died. Good chance that was my problem. I wrapped some tape around it to hold it in place for now. I'll wait a couple days and see if that solved it
Old Apr 17, 2010 | 06:59 PM
montana_highboy
That very well could be your problem, i never did like those "horseshoe" clips, i always change mine over and use the coils with threaded studs so there's no doubt i have a positive connection.
Old Apr 17, 2010 | 08:41 PM
bmuhlbach's Avatar
bmuhlbach
Auto krafters sells new horse shoe connecters.
jimbo285
Jun 19, 2017 06:00 PM
chrisginco
Apr 25, 2013 04:36 AM
jle70
Aug 16, 2012 06:16 PM
Itch71
Jan 3, 2008 01:24 PM
beno
Bronco II
Aug 13, 2003 07:24 AM
