engine shuts off random
Old Jul 24, 2012 | 09:39 AM
jle70's Avatar
jle70
For a while it just shuts off, no symptoms.
Usually it starts right back up.
Now it dies and will not start, maybe lack of fuel?
Old Jul 24, 2012 | 10:58 AM
fordpride's Avatar
fordpride
Sounds like a CPS
Old Jul 24, 2012 | 11:01 AM
jle70's Avatar
jle70
i just put one on in spring, could it have failed again?
Old Jul 24, 2012 | 11:03 AM
fordpride's Avatar
fordpride
Yep. Where did you get it?
Old Jul 24, 2012 | 11:07 AM
jle70's Avatar
jle70
o'reilly auto parts
Old Jul 24, 2012 | 11:43 AM
DarkStarMedia's Avatar
DarkStarMedia
Originally Posted by jle70
o'reilly auto parts
Get a ford CPS....
Richard
Old Jul 24, 2012 | 11:52 AM
fordpride's Avatar
fordpride
Yep go to Ford or International and get one
Old Jul 24, 2012 | 12:09 PM
jle70's Avatar
jle70
ok. thanks. I just did not see how it could fail so soon, but it makes sense.
Old Jul 24, 2012 | 12:40 PM
jle70's Avatar
jle70
just went out and it started right up. it sat for about 3hrs.
Old Jul 24, 2012 | 02:08 PM
427 fordman's Avatar
427 fordman
Still probably the cps..
Old Jul 24, 2012 | 07:50 PM
madpogue's Avatar
madpogue
When it fails, do you see the tach moving when you try to start it?
Hot CPS failure is not uncommon, on any vehicle so equipped. The CPS on the old Saturns is a _crank_ position sensor, and is famous for causing a stall, no-start when hot. Cool down, sensor returns to normal op, car starts, runs until a certain temp when the CPS fails again. Rinse, repeat.
Old Aug 16, 2012 | 06:16 PM
jle70's Avatar
jle70
Sorry did I did not reply sooner.
It was the CPS. I did have Tach movement when cranking over, so it was confusing on what caused problem.
For future reads by "searches".
1. engine shutting off, random, was able to restart
2. tach still showed rpms during cranking
3. towards the end, engine would only run for 10-15 min, then after cooling back down, would restart.
mcguirehg
Jan 11, 2014 11:04 AM
Redneckmorton
22
Nov 23, 2012 06:12 PM
HTi-Enright
Nov 24, 2009 06:16 AM
usherac21
Aug 30, 2008 12:38 PM
hokie
Feb 24, 2005 10:29 AM
