Fuel Pump Delivery module possible Problems?
Old Apr 14, 2010 | 02:58 PM
Shaunjr_89's Avatar
Shaunjr_89
I have a friend who has a 2004 F-150, He says there has been a large problem with the Fuel pump Delivery modules on 04-08 F-150's Anyone else heard about this if so any info on it would be great thanks.
Old Apr 14, 2010 | 03:40 PM
LightningRyan's Avatar
LightningRyan
It's Diag'd on a no start situation. The Module stops working your truck won't start. The funny thing is that the new part is on a massive backorder but you can order 6C2Z 9D372 A, take out the studs and it's the same
Old Apr 14, 2010 | 04:00 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
its only a problem in snowy areas as the unit sits on cross member behind spare tire and salt gets up there and over time eats a hole in the alum.cover lets water in and shorts it out.
drop the tire in the spring wash the unit off put some grease on it good till next spring.
Old Apr 14, 2010 | 04:42 PM
formula74's Avatar
formula74
Search the forums, I had the same issue and explained it, Search for FPDM or check out the links below
https://www.ford-trucks.com/forums/9...er-module.html
https://www.ford-trucks.com/forums/9...2004-f150.html
https://www.ford-trucks.com/forums/9...tart-help.html
SiscoKid
Sep 15, 2022 04:44 PM
brawnk
Nov 10, 2016 02:03 PM
Jonnys.1991
Apr 11, 2016 08:18 PM
joewizl
2004 - 2008 F150
May 16, 2015 08:48 PM
protow2000
Aug 12, 2006 11:12 AM
