Fuel Delivery Module or Fuel Selector Valve
I just bought a 1995 (8/95) F350 w the 7.5 Liter Gas Engine
Seller said he recently replaced front tank pump. However, was having issues w rear tank
What I found is that the rear tank is being filled up w gas to the point it flows out the filler tube.
Was initially told this was a Fuel Selector Valve problem. However, I have been under the truck and traced the fuel lines and do not see one.
I have also been told that this truck does not have a FSV and the issue is handled by a valve IN the Fuel Delivery Module (fuel pump assembly) in the tank.
Do any of you have the actual low down on this?
The problem could be either the high pressure check valve (filling and low pressure) or the shuttle valve (just filling). Both valve and others are located in the FDM.
In your case as noted above the rear FDM is the problem with the bad valve as to why look at the diagrams below.
Your fuel system:
The FDM:
Your fuel system:
The FDM:
Because they don't know how the fuel system works. It makes sense that to select one of two fuel tanks there would be a fuel selector valve. And it makes sense that if fuel is returning to the wrong tank that it would be a problem with the fuel selector valve. If the truck actually had a fuel selector valve it would all make complete sense. But since it doesn't, it's just wrong.
NEW ISSUE
Hey Guys.
So I finally got around to replacing the FDM but I have run in to a new issue
I need a Fuel Filler Neck and it is an obsolete part. I have looked everywhere I can think of and cannot find one.
The closes thing I can find to it is for a diesel. It appears to be the same thing but without the restrictor that requires you to use the leaded fuel nozzle.
Do any of you have any other suggestions?
Could you cut the rusty portion off and just run a longer hose? If not here you go:
1987-1997 Ford F150 F250 F350 Fuel Tank Filler Neck Rear Tank
Jonnys.1991
04-11-2016 08:18 PM
Ole Reliable
17
07-05-2013 06:19 AM
timbersteel
04-06-2010 07:44 PM
HELP91F150
05-06-2007 01:13 PM
