Hello all! First time post. I have a fuel problem with my F150. Pulled the tank, checked the pump(works) finally found out about the module on the crossmember. Mine is #F2A-9D370-CA. I live in a heavy salt using area for snow/ice. Mine is heavily corroded and has a crack in it. Everthing else checks out electrically. I see on 03/28/10 DWS57 posted regarding his 4.7 and the fix was another module /different model vehicle. Does anyone know which part # or model module will work for me. Thanks,
Waddster
