Rusty Cab: Fix or Replace?
Old Apr 13, 2010 | 12:19 AM
FordmanShane's Avatar
FordmanShane
Originally Posted by 73 ford guy
I took this pic just the other day. Its a good cab minus the corners and floor section in these spots. I figure its a typical rust spot on these and I've used cheap aftermarket china replacement cabcorners before but with the jumping and offroading style I do I collapse the thin sheet metal. I cut the entire section out on each side(2'x2' square holes) and started to fit in them today. Im using 1/16 galvanized pieces formed to the shape I need. The cab mount will be custom as well using 1/8 plate. I just need a good starting point with a good floor to be able to weld on the new mount. I figure if I change my cab again,which I'm sure I will in the next couple years after I smash this one, i'll be able to cut this section out and transfer over to the new one.
I'll post pics tomorow of my patch job I started to weld in tonite when I get time tomorow..
yep... the floor in my can looks like that, that's why i asked you... if it was safe to cut and weld with the gas tank still in the cab..you know...it just does sound like a good idea lol
so i guess when i swap tank with a bronco II will be the perfect time to do a lil extra fab work.
Old Apr 13, 2010 | 12:37 AM
sdg0080's Avatar
sdg0080
if it doesnt sound like a good idea then i wouldnt do it. better safe than dead...or crispy
Old Apr 13, 2010 | 11:58 AM
proford1's Avatar
proford1
i don't know where you are located but i have a nice 99 percent rust free cab located in Jay Florida id sell for 600.00 or 1000.00 for the whole truck minus bed. ford706@aol.com
Old Apr 14, 2010 | 09:33 PM
73 ford guy's Avatar
73 ford guy
heres my update on what i did.
its all 1/16 galvinized sheet metal.
Cab corners will be 1/8 or 3/16 indistructable.
Old May 26, 2010 | 10:50 PM
79FordBlake's Avatar
79FordBlake
Now that is awesome work right there, come to my house and do my Bronco, lol.
Old May 27, 2010 | 08:31 PM
dynamic's Avatar
dynamic
Here is a picture of my Dennis-Carpenter cab mounts and LMC body mounts!
Old May 28, 2010 | 09:01 AM
73 ford guy
I never did update my cab mount I made....
I ended up making it out of 3/16 plate stuff I had left over from my bumpers. Way overkill but will NEVER bend.
Old May 28, 2010 | 09:05 AM
dynamic's Avatar
dynamic
NICE JOB!
BII Plow Truck
May 4, 2017 12:18 AM
vidaliaman
Feb 9, 2017 03:26 PM
Frank250Tank
May 27, 2016 04:11 PM
KICKEDBACK
Sep 30, 2015 10:18 PM
fsbronco1989
Sep 15, 2015 08:56 PM
