Please Tell Me My Cab Corners Will NEVER Rust, or is there steel in that area?
EVERY Ford truck for 40 years has or will have rusty cab corners. (Ok, unless you like in a dry state). If only Ford put a drain hole in through 2016.
I know the new 2017 cab is made up of mostly aluminum alloy, but there is steel for various reasons in key areas. Are the Cab Corners a key area?
My understanding is the cab corners are all aluminum, but that said we may not be in the clear. Aluminum can still oxidize and corrode, and unfortunately the 150's haven't had the Aluminum bodies long enough to tell if they will last forever, yet. So knowing that you plow and more than likely deal with salt and harsh winter chemicals (if they spray the de-icer stuff in your area) you may want to check into some of the 5 year old F150's in your area to see if they are starting to show paint flaking in the cab corners.
The firewall is steel, the rest of the cab is aluminum.
Rusted out cab corners are a common problem for Ford trucks, so much so that they have been reproduced for (at least) 1961/79.
A current thread posted by a member of the 1957/60 forum is looking for cab corners....hasn't been able to find any.
Another rust problem is the drip rails. Ford spot welded the drip rails to the roof, then used paintable caulk to fill in the gaps.
The caulk chips off, water seeps in, rust begins, soon spreads into the roof.
.........So knowing that you plow and more than likely deal with salt and harsh winter chemicals (if they spray the de-icer stuff in your area) you may want to check into some of the 5 year old F150's in your area to see if they are starting to show paint flaking in the cab corners.
Thisguy65
05-22-2017 09:26 AM
hasteranger
24
08-19-2013 11:36 PM
1957F100
08-03-2010 09:52 AM
