I have a 2002 F350 7.3 and presently use Chevron Delo 15w40. In the past I have used Shell Rotella 15w40/ Motorcraft 15w40 and alaways the Motorcraft # FL1995 oil filter from WM for around 10 bucks. If you live live in a colder climate you can buy the Shell Rotella 5w40 synthetic oil for about 19 dollars a gallon at WM.
Rotella 15w40 in the summer and 5w40 in the winter. I just bought some 15w40 in a 2.5gal jug from walmart for 27.00 each, comes out to 10.50 a gal. Also I use the motrocraft filter.
Jrod
Jrod
thats a good deal i will have to look for it. i love rotella.
I also do the 15-40 Rotella from Wallet World and either the Motocraft or Extraguard filter. I bought some in there yesterday for $27.00 in the 2.5 gal jug, but a case of quarts was $39.00 . The marketing guru's will getcha if you don't pay attention! Also, Castrol 5-30 (for wife's ride) was $3.77 a quart but a 5 quart jug was only $13.00! Watch your wallet men, cause they are after it!
Another Delo 400 user here. Usually $9-$10/gallon at Costco, so with MC filter at WM for $10, I'm under $50. Add to that a Blackstone OA at $22, I spend under $75 for a comprehensive oil change every 5k miles.
