3/4 ton 150
Old Apr 9, 2010 | 10:04 PM
JaysRanger's Avatar
JaysRanger
3/4 ton 150
i got a 91 ford 150 4x4 and i have a front end out of a 86 250 4x4 that is leaf sprung can i put the leaf sprung front end under my 150?
Old Apr 9, 2010 | 11:30 PM
85e150's Avatar
85e150
If you have to ask, probably not.
Look at it. It's all different, isn't it?
You good at fabrication and welding?
Old Apr 10, 2010 | 12:23 AM
Ford_Six's Avatar
Ford_Six
The front of the F150 frame has a bit of a crumple zone to it, so it takes major fabrication to bolt up leaf springs.
The only gain from the F250 TTB is bigger brakes, it's still a D44 based system, still the same size axle shafts, same size ball joints, and a much harsher ride.
Old Apr 10, 2010 | 08:20 AM
b_eastep's Avatar
b_eastep
iv done it to my 80 bronco. you better really want to do it.
Old Apr 10, 2010 | 01:06 PM
JaysRanger's Avatar
JaysRanger
well could i just use the 8 lug outers on my half ton?
Old Apr 14, 2010 | 11:46 AM
dicksshortwide66's Avatar
dicksshortwide66
Chances are. Measure, measure, MEASURE. They should be the same from the balljoint out, the solid axles are.
Old Apr 18, 2010 | 01:36 PM
fordman1090's Avatar
fordman1090
I don't believe that you can use f250 dana 44hd outer on a f150 dana 44, i looked into it, but everything i read said no.
But, it is possible to get the outers from a 69-82(or so) 4x4 chevy 3/4ton suburban and use the spindle, caliper mounts, outer axle shaft, hub, rotor and caliper. You get the 8 on 6.5 lug pattern and HUGE chevy 1-ton brakes. It works great for me.
bupton
Dec 2, 2012 05:01 PM
admzta
Jan 15, 2011 05:44 PM
Skip1970
Mar 2, 2010 02:57 PM
kristie
Offroad & 4x4
17
Feb 14, 2009 12:03 PM
rustyolred27
Sep 17, 2003 09:05 AM
