Offroad & 4x4
Dana 60 conversion
Old Aug 17, 1999 | 10:11 PM
kristie's Avatar
kristie
Dana 60 conversion
I need info on converting a leaf sprung Dana 60 to a coil sprung Dana 60 for a '79 F-150 4 X 4.
Old Aug 19, 1999 | 12:06 AM
Eric's Avatar
Eric
Dana 60 conversion
Ford does not make a coil sprung dana 60 but it may be possible to fabricate the coil mounts on the dana 60 front diff(but it will be expensive) What I did was install the Dana 60 in the rear and just converted my dana 44 front diff to 8 lug hub and rotors from any f250 with a dana 44 front end hope this helps
Old Aug 19, 1999 | 05:23 AM
Chuck P.'s Avatar
Chuck P.
Dana 60 conversion
Hi Kristie,
One place to check for what your after is a company called Danatrac, they can make just about anything you might want. However it won't be cheap. Their phone # is 714-898-5528, and they are in Ca., only other option would be to find a good fabricater and have the perches, trac-bar mount and radius arm brackets welded to a 60 housing, and then figure out the steering set-up.
Good luck and let me know if Ya go with the 60 set-up-I'd be interested to know final cost of the project and how it all worked out. Chuck P.
Old Aug 19, 1999 | 05:02 PM
H8monday's Avatar
H8monday
Dana 60 conversion
The company is actualy called Dynatrac,the number is correct.They built the Dana 44 for my Wrangler.It is a little pricey to have a custome made axle about $2000 and up.But if you consider that changing the ring and pinion($500-$700),installing a Detroit locker($500),and replacing inner and outer bearings and seals($200),new U-Joints,steering knuckle bushings,etc. it really isnt that bad. There are afew other good companies like Hicks 4x4 in Pomona Ca.909-865-7170, Currie Enterprises in Anahiem,Ca. 714-528-6957, Sams Off Road in Tulsa Ok. 918-446-5535. You just need to shop around.
Welding your own spring perches,and other major welding modifications can damage the axle if not performed propperly.
Jeff
Old Aug 27, 1999 | 10:24 AM
Chuck P.'s Avatar
Chuck P.
Dana 60 conversion
Thanks for the correction(brain was in park?) and the $ figures for your conversion. I'm kinda leanin' towards some custom driveline work just not really ready for the outlay of greenbacks quite yet! Thanx again, Chuck P.
Old Aug 29, 2001 | 04:59 PM
tx4wheeler's Avatar
tx4wheeler
Dana 60 conversion
If the D60 is on a 78-79 model there isnt very much axle tube on the drivers side and that makes it difficult to swap to the coils. Here is a good write-up on the swap.
http://www.dahorse.org/swap%20info/Dana%2060%20front%20into.htm
Old Aug 29, 2001 | 11:06 PM
butaford's Avatar
butaford
Dana 60 conversion
I believe Jeff's Bronco Graveyard has a kit that allows a 60 to be mounted into a 1/2 ton, using the existing radius arms and suspesion. Not sure about the price, but I don't think it was that much.
Old Sep 1, 2001 | 09:03 AM
arementa's Avatar
arementa
Dana 60 conversion
kristie all of said is true but i have succeded in completing this conversion,although you have to take in cosideration of all the custom work thats involved listed companies that were in use were fabtech,valley spring,and dynatrac,machining would take place in the c-bushings for proper caster and welding would be on the axle for a trac-bar location although this sounds easy if you are a competent welder(not the voyeur type lol)just make sure everything is measured against the old setup and compensate for the extra mass of the d-60,but i must forewarn it gets kind of pricey but well worth it in the end as long as the new hulk isn't a worn outjunker hope this help and let me know after you complete it or if you need any more help.hafa adai.
Old Sep 2, 2001 | 07:30 PM
rdnck4x4's Avatar
rdnck4x4
Dana 60 conversion
Old Nov 5, 2008 | 05:33 PM
ns_redneck's Avatar
ns_redneck
its not as hard as most people think. check this site out. it will show you how using all the dana 44 suspension, if u want to run anything bigger then 35's i recomend the dana 60
Bronco Dana 60 Conversion
Old Nov 5, 2008 | 10:12 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
HOLY SHEET!
Is it bad I read everything down to where Redneck came in before I even checked the date?
Old Nov 6, 2008 | 06:24 AM
ns_redneck's Avatar
ns_redneck
wow. nope sure didn't. just stubled across it searching the net for kiing pin rebuild kits. oh well. guess ill look at the date next time lol.
Old Nov 6, 2008 | 10:03 AM
fishmanndotcom's Avatar
fishmanndotcom
actually, i really appreciate you searching!
most just post a thread that was discussed two threads ago and then get mad when we refer them to that one.
Thank you!
-cutts-
Old Nov 6, 2008 | 01:04 PM
Matt983's Avatar
Matt983
Originally Posted by texastech_diesel
HOLY SHEET!
I did the same thing 'cept I was thinking to myself "why haven't the regular dana 60 guys chimed in yet?" then it hit me... dug up from 1999 lol NICE..
Old Feb 13, 2009 | 10:39 AM
childs's Avatar
childs
Dana 60 conv to F150
First of all the coil spring chairs are on your radius arms not on the front end itself. If you want to keep the front end coil springs you can buy radius arm C- bushing wedges that will fit a Dana 60 you will have to do little grinding (Jeff's Bronco grave yard $89.99. The tie rods will work and the drag link will work but you will have to fabricate a mount for the traction bar.
