broken glow plug
Old Apr 9, 2010 | 12:54 PM
renegade14's Avatar
renegade14
broken glow plug
i have a 97 psd changed my glow plugs a few weeks ago to find the dumb a$$ that had it before me left a broken autolite in there any info on how to get it out without removing the head would be great thanks
Old Apr 9, 2010 | 01:31 PM
Talyn's Avatar
Talyn
can you grab it with some needle nose pliers, or vice grips?
gotta just take your time and work them out. Soak em with pb blaster or some fluid film. The FF will break down the carbon as you work it, and give it lubrication to get out, the PB blaster will break it loose.
Old Apr 9, 2010 | 01:48 PM
renegade14's Avatar
renegade14
i cant get on it with anything its just the element thats in there and its down in a bit i tryed turning it over with the valve cover off hoping it would blow out but no luck
Old Apr 9, 2010 | 08:30 PM
scatgo's Avatar
scatgo
You might want to try that again. But let it soak in the PB Blaster for a while first. Then maybe tap on it with a punch a little to help breake it loose. But be carefull not to knock it into the cylinder. If it starts up thats even better. Should blast that sucker right out like a bullet. O yea, if it blasts out it WILL fly like a bullet. So be careful.
Old Apr 9, 2010 | 08:48 PM
FARM69's Avatar
FARM69
You might try using a small drill bit and drilling the in center of the element to relieve some of the pressure. That all depends on how it broke in there.
I'd soak it for a few days and crank it over. She'll eventually blow out. You might want to remove the hood completely when you do this.
Old Apr 10, 2010 | 04:45 AM
jeep1947's Avatar
jeep1947
X2 what FARM said about the hood. Just like shooting it with a gun when it comes out. Good luck.
Old Apr 12, 2010 | 06:58 AM
renegade14's Avatar
renegade14
thanks guys i will try that
Sparky0486
Oct 5, 2011 09:27 PM
mabc926
Oct 12, 2010 04:03 PM
dbyrne
Jan 4, 2006 06:21 PM
noey
Jun 15, 2005 09:42 PM
Drover
Apr 14, 2005 10:36 PM
