Glow plugs broken tips
Old Aug 8, 2000 | 11:30 PM
noey's Avatar
noey
I fried all the glow plugs in my '86 F350 6.9 Crew cab dually. There's a few with the tips missing, which indicates that the broken tips are still in the cavities. Will I have to retrive the broken tips or will it be alright leaving them in. If I have to, how do I remove the tips?
Thanks
Old Aug 9, 2000 | 10:05 AM
deleontow's Avatar
deleontow
More than likely they have already gone out the exhaust. This problem you discribe is caused by the glow plug burning out, (staying on too long) you may possibly have a bad controller.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old Aug 9, 2000 | 01:40 PM
noey's Avatar
noey
Thanks for the reply. Yes the controller stayed on too long which fried the glow plugs. I did have one broken tip stuck in the cavity which prevented the new glow plug to be insert all the way. I tried blowing it out with air, then I tried using a jet-vac but no sucess so I drilled it (with very little pressure) and the broken tip popped thru. Hopefully it will blow out the exhaust.
Old Aug 9, 2000 | 01:57 PM
deleontow's Avatar
deleontow
Just for info, next time, try cranking the motor with the plug off, 300 p.s.i. or more will sure blow that glow plug tip right out.
Dave
Old Aug 10, 2000 | 05:16 PM
dob's Avatar
dob
Old Jun 15, 2005 | 07:53 PM
Chevy_Eater's Avatar
Chevy_Eater
Dave
Yep, that's what I did, placed a rag over the hole to catch it and cranked it over, spit it right out.
Old Jun 15, 2005 | 09:42 PM
PLC7.3's Avatar
PLC7.3
""but no sucess so I drilled it (with very little pressure) and the broken tip popped thru. Hopefully it will blow out the exhaust.""
If it does you can list your name in the Guiness book of records.......
Visit this page....... http://www.members.shaw.ca/k2pilot/
big ole ford
Mar 11, 2017 09:21 PM
akpolaris
Jan 15, 2017 11:02 PM
terrymargate
6.7L Power Stroke Diesel
Nov 25, 2015 09:16 PM
panningbros
Mar 12, 2011 01:17 AM
firemanp
Dec 15, 2006 03:47 AM
