glow plugs?
Old Sep 18, 2011 | 07:53 PM
Sparky0486's Avatar
Sparky0486
glow plugs?
well I started my truck this morning and had white smoke so I tested the glow plugs and had two of them reed a infinit connctent could that mean the glow plug is bad or one of the wires in the wiring harness be broken.
Old Sep 18, 2011 | 07:57 PM
F350-6's Avatar
F350-6
Could be either one. What year truck do you have? Some of the early ones had issues with the glow plug wires rubbing against a push rod, which would short out that wire.
Ever pulled a valve cover before?
Old Sep 18, 2011 | 08:00 PM
Sparky0486's Avatar
Sparky0486
I have a 02 f350. I have pulled valve covers before but not on this truck
Old Sep 18, 2011 | 08:06 PM
F350-6's Avatar
F350-6
So you shouldn't have the old harness then.
Pulling valve covers is the same as any other vehicle, just a bunch of stuff in the way. Some swivel joints and extensions and you should be fine. The valve cover gasket is re-useable. No RTV needed. The only thing to really watch for is the nut holding the dipstick in place. The nut only holds the dipstick, there is another nut on the stud below the dipstick flange. If you try to loosen that nut and the dipstick starts to twist, stop. Put a back up wrench on the nut below or grab the dipstick flange with some channel locks so you don't ruin your dipstick tube.
Old Sep 18, 2011 | 08:14 PM
Sparky0486's Avatar
Sparky0486
Ok thanks for your help. I have new set of glow plugs on the way
Old Sep 18, 2011 | 08:26 PM
F350-6's Avatar
F350-6
What brand? Please don't say Autolite. We've had too many stories about autolite and several aftermarket glow plugs where the tip swells up and breaks off in the head when go to remove them next time.
As long as you've got the valve covers off, you might as well do some other PM work while you're there. Ford sells some shims for the UVCH connector you can use, or you can trim the top off a quarter like this
and slide it inside the connector like this to keep it from coming unplugged on you later.
Also check the torque on the lower injector hold down bolts (circled in blue) to 120 in lbs and the rocker arm pedestal bolts (circled in red) to 20 ft lbs.
Old Sep 18, 2011 | 08:37 PM
timmyboy76's Avatar
timmyboy76
Chris, from that last pic, where do you go from there to install pushrods, if one wanted to? As simple as removing the nuts, remove the rocker arm and pull up/out the pushrod?
Old Sep 18, 2011 | 08:45 PM
Sparky0486's Avatar
Sparky0486
i bought motorcraft glow plugs, and yeah your right I might as well do some pm work. thanks again for all the help and any advice is greatly appriated
Old Sep 18, 2011 | 10:28 PM
timmyboy76's Avatar
timmyboy76
these are sweet...
Riffraff Diesel: RDP Plenum Reinforcing Inserts™
Riffraff Diesel: RDP Complete CAC Intercooler Boot Kit
No more boost leaks.
Old Sep 19, 2011 | 06:23 PM
F350-6's Avatar
F350-6
More or less. There's a spring type clamp you can see on the side of the pedestal, there's a little ball under it, you need to rotate the crank until the mark on the damper is at the 11:00 position, or rotate the engine for each cylinder (11:00 for all is easier), and remember copper side up when you re-install. (different color ends on the push rods)
Old Sep 19, 2011 | 07:14 PM
timmyboy76's Avatar
timmyboy76
Ok, so set motor at 11:00, then i can start removing ALL pushrods? Or remove everything, then for install, set motor at 11:00? I see the "clamp" you referring to. Under it, is a ball. Will the ball fall out, spring out..? Pushrod maker, go with motorcraft again or find a/m ones? Thanks Chris...
Old Sep 19, 2011 | 07:36 PM
F350-6's Avatar
F350-6
Roll the damper to 11 first, then do them all. Unless you've got a reason to, I'd stick with the stock ones from Ford / International, and unless you've got a reason to pull them, I'd leave them alone. It's not like the metal gets weak from the engine running, but you might want to ask some of the guys who are more into the heavy mods for their opinion.
Old Sep 19, 2011 | 09:06 PM
timmyboy76's Avatar
timmyboy76
Nah, nothing about modding the motor. Just bombing around "googling" and seeing "bent" pushrods, time to time, with not many miles on it. So, just another preventative, to say the least
Old Sep 20, 2011 | 07:38 AM
Ponyboychris's Avatar
Ponyboychris
Pulling valve covers are not bad at all but the first time you will have some "ah - ha" moments so when you pull them again, you will do it in no time. Here's a write up I did with some pics that may help you.
Glow Plug Install 10-10 pictures from trucks photos on webshots
Old Oct 5, 2011 | 09:27 PM
Sparky0486's Avatar
Sparky0486
Well Finally got around to changing the glow plugs and while I was there I did the pm work and quarter mod. thanks for your help everyone
MustangMatt96GT
27
Sep 26, 2009 07:34 PM
broncobran68
Aug 16, 2009 02:43 PM
mtford
Apr 20, 2009 07:32 AM
HP junkie
26
Oct 25, 2006 07:55 AM
psch1223
Nov 30, 2004 08:34 AM
