glow plug harness interchange
Old Apr 13, 2005 | 04:48 PM
Drover's Avatar
Drover
i have a broken connector where the glow plug harness connects to the wiring coming from the relays and solenoid(86 6.9idi ). its the relay side that is broken. does the 7.3idi use the same connector? I know where i can get a harness off a 7.3idi. i know the glow plug harness is different(spade vs. bullet) thanks
Old Apr 13, 2005 | 09:01 PM
PLC7.3's Avatar
PLC7.3
Are you talking about the 6 wire engine harness connector, does it have the two large yellow wires in it. If so this is a bad connector and susceptable to burning up.
Old Apr 13, 2005 | 10:31 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The 7.3 does not use the same connector.
The 87 6.9 does not use the same connector.
When I burnt mine up I just cut the connector out and spliced the wires together.
Everything worked perfectly.
Ford Does not have the connector either, unless you but the entire wiring harness on the truck and engine side of the connector.
Old Apr 14, 2005 | 10:36 PM
Drover's Avatar
Drover
cool thanks for info.looks like a'splicing i will go!
Codeman894
Sep 28, 2017 08:59 AM
Texasthb
Jul 24, 2015 12:09 PM
Yazmar9
Dec 14, 2013 03:52 PM
CoalRoller7.3
Oct 23, 2012 08:22 PM
