Electrical conondrum
Old Apr 10, 2010 | 06:35 PM
  #31
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Well,
$249.99 + $85 core + a new $140 850CCA battery I didn't need I am happy (or not)
13.2V at rest 14.6 while charging
Oh, and I decided to install a new solenoid while I had everything torn apart. Genuine Motorcraft, from the dealer.
Guess what......
The d@#^ thing fused on the first crank.
GAAAHHHHHH!!!!!
Old Apr 10, 2010 | 06:39 PM
  #32
quicklook2's Avatar
quicklook2
are you shy about what fixed it?
Old Apr 10, 2010 | 07:07 PM
  #33
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sure???
Yes, the alternator was bleeding almost 5 Amps.
I have continuity from charging post to case on the bench.
Old Apr 10, 2010 | 09:19 PM
  #34
Old93junk's Avatar
Old93junk
On a similar note.............I knew a guy who had the same troubles exactly, after spending 300 bucks on cables, solenoid, ign. switch, alt, battery........no fix.
The final word was.............cigarette lighter had jammed in the contact position and was red hot constantly!......he did not smoke, never even looked at the thing. Someone had pushed it in and cost him $300 bucks!
Lucky it did not burn to the ground!
jereli
Dec 26, 2013 10:56 AM
mrberg89
Nov 4, 2012 09:34 PM
Nader
Feb 23, 2011 04:00 PM
daverous
Electrical Systems/Wiring
18
May 11, 2010 12:11 AM
aq65hs
Ohio Chapter
Jan 11, 2005 01:53 PM
