Electrical conondrum
Old Apr 8, 2010 | 07:01 PM
gpedens's Avatar
gpedens
I forgot to mention that a 5 amp draw is as much as some head lights. Have you or family members added any electrical do-dads prior to the problem?
do you have power windows and maybe one of the buttons gets stuck in up?
Old Apr 8, 2010 | 07:13 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Originally Posted by ArdWrknTrk
Will check the solenoid tomrrow.
I'll also disconnect the alternator, but it is less than a year old.
Never seen any other engine management, and I have had the truck to bits.
I'll look for any relays I may have missed.
Ford's been ECUing since 81' that I know of. Started w/ MCU, then OBD-1, OBD-2. My 87' 302 EFI A/T is OBD-1. 87' Carbed may be MCU but there is an ECU either way! The stuff's not easy to find for a reason. We're supposed to think it's all "Magic", beyond our grasp, so we take it to the dealer for everything! One big myth is that base time can only be 10BTDC. I've been running happily at 16BTDC for 4 yrs. now. Computer advance starts from base time whatever it's set at! (not to change the subject)
Old Apr 8, 2010 | 07:22 PM
gpedens's Avatar
gpedens
Dang forgot sumpin else. hood light is about 1 amp, dome light 1 amp, brake light 2 amps, running lights 4.5 amps, glove box 1/4 amp.
5 amps would drain it over night.
Old Apr 8, 2010 | 08:35 PM
danr1's Avatar
danr1
It has a dura spark module, dura spark II IIRC? it doesn't use a relay like a EEC does.
As suggested yea I'd lean toward something added by a PO maybe, something anything added that wasn't run though a fuse?
Old Apr 8, 2010 | 09:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sadly, I am the only owner.
I pretty much know every nut and bolt on this truck personally.
Just a "Custom" so no power windows, A/C, exterior lights, etc...
Yes it is the famous (or infamous) blue grommet DuraSpark II module. But from all the wiring diagrams I've seen it only receives power in start and run.
The distributor has both vacuum and centrifugal advance. Mine is recurved and starts @ 11 Deg.
gpedens,
By "tin can looking" things do you mean the flasher relays? With the turn signal one on the front of the fuse block and the 4 way hazard flasher on the back.
No underhood light and the interior light, ashtray and glove box lights function normally with both door switches.
My harness is in good shape with recent wireloom. (well, 2 years ago when I swapped the engine)
I'm kind of leaning toward a fried triode in the "new" 130A 3G alternator.
I know Ryan McCormick sells them for $40 online.
Old Apr 9, 2010 | 12:02 AM
gpedens's Avatar
gpedens
The flasher things are usually round. The breakers are on the same board as the fuses and they are in little rectangular cans about 1 inch wide by 5/16 thick by 3/4 inch high. Since you have the bear bones type truck, it may not have any breakers.
Did you look under the hood and see how many wires you had on the starter relay? Thats the relay the big red battery cable goes to. it is usually just a foot or 2 from the battery. The starter relay will have 2 big terminals for the 2 big red cables and it will have 1 or 2 small terminals. Check all the wires on the starter relay for current , one at a time. Well you dont need to check the big red one from the battery.
Is there more than one red wire on the red ot + battery terminal? If yes check it too.
Old Apr 9, 2010 | 12:06 AM
gpedens's Avatar
gpedens
Geeze, I forgot to mention if you think it is the alternator, just unplug the wires to the alternator. I think there is one or 2 plugs. Now that I think of it one of the wires from the starter relay probably goes to the alternator.
Old Apr 9, 2010 | 01:31 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes, my Alternator output goes through a 175A Mega fuse and connects to the hot lug of the starter solenoid. There is only one (green w/ red) wire going in and one (red) wire out of my 3G.
I am using an adapter harness like this:
And this,,,,
I also have 3 fuseable links on the hot lug, but no breakers like you describe at the fuse panel under the dash.
I have had the plug on my old 2G melt twice. Good riddance!
Old Apr 9, 2010 | 05:33 AM
fmr9's Avatar
fmr9
Had a diode fail in an alternator. Didn't measure the amp draw, but if drained the battery in a few hours.
I would bet on the alternator, but if it is not, you could try hooking the battery up and waiting a couple of hours, then start touching or using an Infrared temp gun to check for something being very warm. That much power will heat up whatever is the problem.
Good Luck Frank
Old Apr 9, 2010 | 06:48 AM
subford's Avatar
subford
NO electric fuel pumps, just mechanical.
Are you sure on this one?
I thought all 460 4V engines in 1987 had electric fuel pumps.
Old Apr 9, 2010 | 06:55 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes, I am sure.
I have replaced the mechanical pump and both tanks at one point or another.
I think you are thinking about 'hot fuel handling' where a low pressure pump circulates fuel up past the carb and returns back to the tank in an effort to eliminate vapor lock.
My truck was ordered from a dealer in Larchmont, NY and may not be optioned this way due to the climate here.
Old Apr 9, 2010 | 06:53 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yep, it's the alternator...
Checked after work today.
And the guy at my local auto parts won't "trust" my application over the phone. He wants me to take it out and bring it to his counter to match up before he will get one from his warehouse.
GAAAAAAH!!!!
Flipping dipstick.
Other things drive off that belt.
I DON'T have time to go over there three times for one part.
I want to pick it up, do it at my leisure and return the core later.
I could buy one off Ebay for $50 + $15 shipping, NOT $189.99 + $25 core + $11.40Tx if I felt like driving around for a week and unhooking my battery everywhere I go.
Old Apr 9, 2010 | 08:06 PM
  #28
gpedens's Avatar
gpedens
ArdWrkn, did you put the amp meter in series with the + battery post and red cable , then unplug the alternator connector and see the current go away? Or did you test the alternator by other means?
Old Apr 9, 2010 | 08:30 PM
  #29
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Aaaa,
I disconnected all the lugs from the always hot post of the solenoid and connected my meter to that end of the battery + cable.
I tried each of the fuseable links first and saw no current flowing when set to 10 amp scale. When connected to the alternator output cable it shot right up to 4.8x Amps.
Old Apr 10, 2010 | 11:11 AM
  #30
gpedens's Avatar
gpedens
thanks ardwrkn, that kind of detail will help the less technical folks. I have one of them clip on DC amp meters that makes it real easy as long as you can get to the wire. Dont even need to disconnect. It will read to about 10 milliamps or 0.01 amps DC. But when you get right down to it, the meter I use the most is one sold by Harbor Freight. They run it on sale for $3 or free with a $30 to $50 purchase. It is a digital meter and will 10 amps DC, check a transistor, 0.2 and 2 vdc scale. I have bought several over the years and keep one in several places. Given several away to the youngins boyfriends or others that seem to be interested in DYI. You can check most car sensors with them. Their biggest weakness is the probe end breaks off fairly often due to the small wire and bending motion using the meter. Main thing to remember is to check it on a known something before you use it, but that applies to all meters and test equipment.
