So I apparently have a "hard code"
Old Apr 8, 2010 | 03:16 PM
HKusp's Avatar
HKusp
I have a new addition to my dash----the check engine light has not gone off today. Now my question is this, I believe on the '02 and '03 models, you can get your codes from the digital readout that is the tripometer/odometer. I know I used it this past fall to look at alternator voltage and stuff like that just messing around. The thing is, I just can't seem to remember the procedure. Anyone here have it?
Old Apr 8, 2010 | 03:32 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Come on Jason, do what you know you want to do. Get a AE from Clay.
DieselCamper01's Avatar
DieselCamper01
Sorry. I am an analog guy. I know there is a procedure but do not know the routine. Good luck Jason
Old Apr 8, 2010 | 03:46 PM
HKusp's Avatar
HKusp
All I hear is the teacher from Charlie Brown Rick.
I would LOVE to buy it but the price has gone up, and I don't have a laptop if you can believe that. My kids BOTH have Netbooks, but I don't have a dang laptop. Sad.
Old Apr 8, 2010 | 03:51 PM
snakedoc's Avatar
snakedoc
i think you hold the button down and turn the key on? not 100% on that.
Old Apr 8, 2010 | 04:09 PM
bdrummonds's Avatar
bdrummonds
turn around three times to the left befroe you open the door, (Aussie models turn to the right) stick your tongue out of the side of your mouth like Michael Jordan used to do, Hop up and down on 1 foot, cuss at it, and then call IZZY (joe) he has the procedure.
All of the above may or may not be necessary depending on your year model, and the severity of the code.
Old Apr 8, 2010 | 04:21 PM
miller_feed
X2^^^^^.
Old Apr 8, 2010 | 04:32 PM
snakedoc's Avatar
snakedoc
X2^^^^^.
X3.........
Old Apr 8, 2010 | 04:48 PM
HKusp's Avatar
HKusp
Thanks Brandon, or should I say"Mr I don't answer the phone"?
Old Apr 8, 2010 | 06:15 PM
Stewart_H's Avatar
Stewart_H
This is the procedure for my Lightning. I can only assume it should also work for our trucks.
Put the key in the ignition, but don't turn it on. Press and hold the trip reset button, then turn the key to the ON position.
Once the key is turned, after a few moments, the lights on the odometer read-out will change. Let go of the button when they change.
Once the read-out has changed, each press of the reset button will scroll through the menu.
If you press the button too long, it will clear out and go back to showing the mileage.
Scroll through the menu choices until you find one that says DTC. If you have a code, it will say DTC2145 or something...OR DTC NONE for no codes
Stewart
PS - One of the menu choices is a digital RPM readout. Kinda fun to watch when you first find it.
Old Apr 8, 2010 | 06:21 PM
Izzy351's Avatar
Izzy351
Stewart has you covered. If you track mileage, you'll lose your trip odometer (it resets), so write it down before hand.
Old Apr 8, 2010 | 06:37 PM
F350-6's Avatar
F350-6
I wonder if this process only works on the standard OBDII codes? I would think you might pick up the common stuff, but not the engine specific codes we typically deal with. Much like the how the cheap scanners won't read most codes on our trucks.
Old Apr 8, 2010 | 06:38 PM
Stewart_H's Avatar
Stewart_H
I too was wondering the same thing.
Stewart
Old Apr 8, 2010 | 06:40 PM
big poppa's Avatar
big poppa
Here's some reading for yaa, started this back a ways. https://www.ford-trucks.com/forums/8...test-done.html Hows the truck running??
Old Apr 8, 2010 | 07:19 PM
HKusp's Avatar
HKusp
Seems to be running good. The light was on every time I got in the truck today. I took it out on the beltway and ran it out a little bit and the light went off. Thanks for the procedure Stewart and Mike. I will let you know what I find. It will probably be tomorrow though.
