Trip Odometer Test Done
Old Jun 18, 2009 | 04:00 PM
big poppa's Avatar
big poppa
I did this test two weeks ago but was busy so i,m posting it up now that I got the chance. Was poking along on here and Joe (Izzy351) had done this and I figured I never seen them posted here, thanks Joe. The test was just like Joe said, with the key off, push the trip button in and hold for about 30 seconds, then still holding the button, turn the key to the start position but don't crank it, then you can scrool thru and see the codes and such. I know it works on my 03, I think you can do it from 02-03 if I remember correctly, here we go, these were on my truck.>> Check bulbs and dash lights, the whole dash lit up. PF3346,SF0E09,0284475,19NIN6,R0503,17R0503,EE01,DT 3831,CF160,CF200,CF300,CF400,DTC9352 AND FLASHING,EN6000,RIC000,EAC0000,F233,FP253,234C,OIL 233,073EF,BR123,BATTERY12.6,RIE00,PRND40,PAR WITH A DIAMOND SHAPE NEXT TO IT,D00Z00,STBT9,CHE01,PA80,PB11,PG1C,P620,PH90,PPD 8,P58-9F FLICKERING BETWEEN 8-9,PT25,PCANSF,AD0000,AD1 24767-8 FLICKERING BETWEEN7-8, AD2246-7FLICKERING BETWEEN6-7,AD3076-7, FLICKERING BETWEEN6-7,AD4-146,AD5-234,AD6-160,AD7-146,GAUGE CHECK, very interesting, found out my volts were 12.6, oil was 233* if thats correct, seems kinda high but still learning.. Pick it apart if you can and try it out on your truck.
Last edited by big poppa; Jun 18, 2009 at 04:50 PM. Reason: 02-03 edit, thanks Joe
Old Jun 18, 2009 | 04:04 PM
DieselCamper01's Avatar
DieselCamper01
Where does it display those codes? How do you translate them? Is the a list of what those mean? Sorry about all the questions. That is pretty coo if it will work on mine also. Thanks Mike and Joe!
Old Jun 18, 2009 | 04:05 PM
HKusp's Avatar
HKusp
What did you do take a note pad out with you?
Old Jun 18, 2009 | 04:07 PM
HKusp's Avatar
HKusp
There is a listing on the main page of FTE with links to all the codes.
Decoders, Codes, Charts, Etc. .: Articles
Old Jun 18, 2009 | 04:10 PM
patrick77598's Avatar
patrick77598
man I wish my truck would display like this. *stupid analog odometer*
Old Jun 18, 2009 | 04:15 PM
HKusp's Avatar
HKusp
My oil was 234* and my volts were 12.1
Old Jun 18, 2009 | 04:19 PM
bigsteve1969's Avatar
bigsteve1969
yea i got the good ol manual setup... it dont do nothin but go 1/2 way between the zeros thats bout all
Old Jun 18, 2009 | 04:29 PM
Adam0331's Avatar
Adam0331
Wow, learned something else.
Old Jun 18, 2009 | 04:34 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Don't work on the '01.
Old Jun 18, 2009 | 04:46 PM
Izzy351's Avatar
Izzy351
It doesn't work on the older trucks because of the analog odo as mentioned... This is an 02/03 thing only, unfortunately. You need a cluster like this:
Old Jun 18, 2009 | 04:57 PM
big poppa's Avatar
big poppa
Thanks Joe, just edited it in my post so not to confuse. Jason, I brought a small piece of paper but had to go in and get more, alot of codes..Adam, try it, you should get something..
Old Jun 18, 2009 | 05:48 PM
DieselCamper01
Bastiches! lol
Old Jun 18, 2009 | 06:30 PM
big poppa's Avatar
big poppa
I,m assuming from that 233* temp of the oil, the PCM read that as the last highest temp. I,m trying to pick some of it apart, I do run the 203* stat and normally running highway speeds so that sounds about right.
zerfetzen
114
Jul 28, 2022 03:38 AM
SBV45
Aug 28, 2018 11:12 AM
Miguel P
General Automotive Discussion
Sep 28, 2016 06:16 AM
12valveEx
Aug 16, 2013 08:24 PM
msgtg
West Virginia Chapter
Aug 12, 2007 10:39 PM
