EBPS question
Old Apr 8, 2010 | 08:33 AM
amthatiam's Avatar
amthatiam
EBPS question
Hello everyone,
What exactly does the EBP sensor do and does it really need to be there? I have deleted both the back pressure valve on the turbo ped and also the butterfly in the exhaust, seems to me that I no longer need it. Is this true? Thanks in advance.
Dan
Old Apr 8, 2010 | 09:10 AM
Pocket's Avatar
Pocket
The sensor monitors exhaust backpressure to control the opening and closing of the EBPV in cold weather conditions.
If you remove the sensor completely, you will trigger a code. On some trucks, it will also keep the CEL illuminated. Basically you can leave the sensor in place, and you should be fine.
Old Apr 8, 2010 | 11:53 AM
kupaa's Avatar
kupaa
Not to hijack this thread but looking at your sig all you need is some fat injectors.
Old Apr 8, 2010 | 01:07 PM
03_PSD's Avatar
03_PSD
subscribed...I've deleted all my EBPV also
Old Apr 8, 2010 | 05:12 PM
amthatiam's Avatar
amthatiam
Crosses my mind once in a while : )
Dan
Old Apr 8, 2010 | 06:12 PM
mongo75's Avatar
mongo75
I thought the EBPS (on the front of the block) is pretty important, especially for your mileage?
Old Apr 8, 2010 | 06:24 PM
Izzy351's Avatar
Izzy351
I like it so I can watch the exh back pressure on my Scan Gauge... Some have claimed mileage changes after cleaning the tube.
EDIT: What *COULD* be happening is that folks have had broken or leaky tubes, and after replacing them, gaining a little mileage (due to fixing an exhaust leak), but I honestly don't see how just cleaning a plugged tube would change MPGs.
Old Apr 8, 2010 | 10:24 PM
Pocket's Avatar
Pocket
Nope.
Mine is actually still plugged into the electrical wiring, but is non-functional. A few years ago I pulled the sensor out of the tube, stuck a plug in the tube, and put a cap on the end of the sensor, then zip tied it to a secure place. Mileage didn't budge, zero difference in power, no changes in smoke, nothing.
Cody (Cleatus) posted a tidbit not too long ago that I plan to try. It's in regards to the EBP and tuning tweaks to eliminate trouble codes for those who have deleted their EBPV. Once I try it, I'll have to post back if it works. Just gotta find time to tweak the tunes on my truck again. Seems like I never have enough time to play with my toys.
Old Apr 8, 2010 | 10:42 PM
canister's Avatar
canister
I deleted my EBPV with a blank pedestal. I just zip tied the unconnected wire to some other wires. Was I supposed to do something with the EBPS or the tube?
tjmike
Feb 2, 2015 09:24 PM
sglass57
Dec 3, 2012 11:12 PM
4x4countryboy
Mar 29, 2012 09:07 PM
SunBum
Aug 17, 2011 02:24 PM
TIM PADGETT
Jun 10, 2005 07:43 AM
