Front Hub & Rotor torque/tension
You need a torque wrench if you want to set it to factory specs.
Tighten the nut to 22-25 ft lbs, turn the wheel a couple of revolutions, check that the nut is still at 22-25 ft lbs. Loosen the nut 1/8 turn, and then tighten it with your hand only. Put the cotter pin in place. If the cotter pin won't line up, loosen it till it does, no more than 1/2 flat on the nut.
on
every single time i try doing this by the book she ends up way to lose.
i always tighten it up extra and just back off a little.
this has been the only way iv had luck.
basically as long as the end results is not to much pressure that she heats up,and not to lose.
once your have it locked in there,its not going anywhere.
never could get it even close by the books methods.always way to sloppy.
huckf1nn9
04-18-2018 06:56 PM
gd98tj
Escape & Escape Hybrid
07-09-2004 11:07 AM
