ENGINE IS OUT!
Old Apr 6, 2010 | 08:30 PM
dyoung14's Avatar
dyoung14
ENGINE IS OUT!
I finally got it out this evening, the tractor wouldnt pick it up its too heavy for the old massey, so i drug it up under the maple tree and used the come=a=long and it come out then, so maybe by next week i will have the truck back to running with an 83 model 6.9 with around 40,000 on its rebuild, but its been setting for some years so it probly wont run good to start with but as long as it gets me from point A to point B i will be good,Does anyone have any advice for me to make it easier? And also what should i do to the other engine while its out before i put it in? And what do i got to do to convert a auto engine to a manual?
Old Apr 6, 2010 | 08:42 PM
Rick Wallace's Avatar
Rick Wallace
Since you are good at taking them out now,come do mine!!I aint got a maple tree ,hows bout an oak tree?
Old Apr 6, 2010 | 08:52 PM
Knox's Avatar
Knox
about how much do our engines weight?
Old Apr 6, 2010 | 09:40 PM
starmilt's Avatar
starmilt
860 to 920 pounds dry, with no accessories or flywheel or oil.
Old Apr 6, 2010 | 10:13 PM
dyoung14's Avatar
dyoung14
Oak tree will work, its just agrivating, i cant wait to put the other one in im sure it will be lots of fun
dyoung14's Avatar
dyoung14
TOO MUCH!!! lol
Old Apr 6, 2010 | 10:22 PM
Dave Sponaugle's Avatar
Dave Sponaugle
When you have everything on it, use 1200 pounds for the weight.
Using an engine hoist, get the biggest thing you can find, 1200 pounds high enough to clear the radiator support is scary.
Old Apr 6, 2010 | 10:27 PM
mechelement's Avatar
mechelement
Did you finally break your motor? I must've missed that thread.
Old Apr 7, 2010 | 12:50 AM
Red Cobra's Avatar
Red Cobra
x2........
Old Apr 7, 2010 | 12:54 AM
starmilt's Avatar
starmilt
It came uncranked.
Old Apr 7, 2010 | 01:34 AM
peruses's Avatar
peruses
I cut and scbbed the upper section of the radiator support so now the highest thing I have to lift it off if the moter needs to come out again is the bumper
Old Apr 7, 2010 | 03:38 AM
Sycostang67's Avatar
Sycostang67
If the motor has been sitting for several years, I would be changing every rubber seal and gasket it has.
You guys missed the dead motor post? It was on april 1st so nobody believed him.
Old Apr 7, 2010 | 07:37 AM
greywynd's Avatar
greywynd
So the 15 ton excavator with a lifting capacity around 4-5 tons should suffice?
Anyone looking for practice, I have 2 to pull, and one to install here this summer by the looks of things.
Old Apr 7, 2010 | 05:57 PM
kenpobuck's Avatar
kenpobuck
Not me. I have pulled are replaced tomany engines and trannies in the last year. Now with this fairlane I am getting i get to do it all again lol.
Old Apr 8, 2010 | 09:57 PM
dyoung14's Avatar
dyoung14
Yes happened april 1ST wasnt reeming on it it was running good besides my air leak problem i had, when it blew it was taching around 1500 rpm, i think i finally found out why it died, my buddy sprayed some either in no telling how much, and then i sprayed some in not knowing he had already so, it tryed hydrolocking but didnt have any choice but to sling rods and ruin a block, so as of now, high RPM dont kill
