i got a 92 f150 with the 5.8 in it i just put an oil pump in it and a oil sensor in it and i hold preusseure fine but when the motor gets warm i loose oil pressure when i come to a stop. when i get goin again i picks back up then go to stop or slow down. im stumped! any ideas? when i changed the oil pump the parts guy said i wouldnt need a new pick up screen would it be that?
That is how it works in almost any engine, when the oil warms up and you are at a low rpm your oil pressure is not going to be as high as when you are running at a higher rpm because the oil has to flow faster at higher rpms. And when your oil is cold it does not flow as well which would also cause your oil pressure to be higher too. How low and how high of oil pressures are you running? And what weight of oil are you using?
im runn 10w 30 in it. when i come to a stop i loose all oil pressure and my truck just dies. when driving itll hold pressure at the m in normal only gauge it gots. but stop at stop sign or light it looses all and dies
I asume you have an OP gauge & the oil pressure goes to 0 then the truck dies ??? When the motor starts to stop runing your going to lose OP because the oil pump will slow down & stop ....Lew
yes normal gauge. but why is the truck dieng when i go stop? it runs fine til i go to stop then motor dies and restart it to leave every light? i hadda put it in nuetral keep rpms up at a light just so it dont die.
when old oil pump went out motor shut off everything was good. i took off the oil filter it was empty no oil not even a drop so i changed the pump and sensor and there is no lifter clatter or nothing when motor is running it sounds great
i stopped at friends house house the motor just died. i went to start it back up there was no oil pressure so i towed it home pulled the oil filter it was dry so i replaced the oil pump was told to just clean pickup screen put new gasket on it a new oil pressure sensor and gave it a oil change used 10 w 30. truck started right up with oil pressure then i drove it for bout 20 min and all of a sudden i stopped at a light and lost oil pressure truck died. i waited a bit checked oil started up ran good til hadda stop again. towed it back devastated! my first ford i love the bodystyle! lol
